Home > In Car Electronics > Work Lamp Remote Switch?
SS90
Is it possible to rig up a work lamp that can be controlled remotely by something like a key fob switch as well as a std switch?
Post #394113 30th Jan 2015 5:43pm
theorangebandit
Bolt on bits do a remote switch it has a load of functions like disco flashing and strobe but also solid beam too
Post #394121 30th Jan 2015 5:54pm
SS90
Thanks, tried looking but do they have a website?
Post #394128 30th Jan 2015 6:09pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Only an flea bay shop as far as I've ever found
http://stores.ebay.co.uk/Bolt-On-Bits-01274-688-388 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #394277 30th Jan 2015 11:50pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
My £14 after market alarm has a remote start function, I've wired this up to the work lamp relay so the start up button turns the work lamp on instead. Works a treat and the standby energy consumption doesn't even register on my watts up. I also wired it up so somebody sets my alarm off, the 18w LED work lamp flashes instead of the indicators, this draws much more attention Twisted Evil
These tons of cheap chinese controllers on ebay and amazon.. just search for 12v wireless switch, but remember they don't support high current, even LED lamps are too high - you need a relay for the lamp and have the receiver to control the relay instead Thumbs Up
Post #394388 31st Jan 2015 12:34pm
K9F
A few options....
This one has a 10 amp rated output and looks to be best suited for your needs......
http://www.amazon.co.uk/Daytime-Running-Re...mote+relay
Lower output.....
http://www.miniinthebox.com/12v-2-channel-...wgod1YIAzA
http://www.amazon.co.uk/Dpower-Wireless-Co...mote+relay If you go through life with your head in the sand....all people will see is an ar5e!!
Post #394410 31st Jan 2015 1:54pm
excossack
Something like this?
http://www.ebay.co.uk/itm/12V-4CH-200M-Wir...43d46d2e68 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #394435 31st Jan 2015 3:40pm
