Home > Puma (Tdci) > Drip drip drip
Page 2 of 2 <12
Gleaney
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Ok. Update on the bloody leak.
Basically. Yesterday I noticed the head lining above the passenger side just above the window was wet and sagging a bit.
And what was happening was water was coming through the alpine window and finding its way down the inner guttering and into the head lining above the passenger window, pooling up over time then finding its way down the A post and coming out just behind the dash and onto the passenger footwell.
The guys at Lloyds Autobodies in Manchester have dried the headlining out and sealed and replace the seal on the alpine window.
Hope this helps people with a similar problem. Also ordered some Captain trolley creeping crack cure just as a belt and braces. Damn planet is short of Kryptonite !
Post #394344 31st Jan 2015 10:42am
K9F
Wet headlining could be cracked roof gutters....
http://www.defender2.net/forum/topic5842.h...headlining
As you have airconditioning it may be worth getting underneath and checking the drain teat if it is clogged and modifying it by cutting it if it is......
http://www.defender2.net/forum/topic14249.html?highlight=drain If you go through life with your head in the sand....all people will see is an ar5e!!
Post #394348 31st Jan 2015 10:50am
Gleaney
The guys water tested it and the alpine seal wasnt seated right. And I looked at the roof gutters and there's no cracks in there. Thumbs Up Damn planet is short of Kryptonite !
Post #394350 31st Jan 2015 10:55am
nitram17
Gleaney wrote:
Chaps do you think there is a possibility of water getting at the back of the hinge and dripping behind and finding its way along the rivets to the inside of the bulkhead?
Fill the gap with acf grease but i doubt that thats the cause of your problem!
Post #394887 1st Feb 2015 6:16pm
lohr500
My 12MY is also leaking into the passenger footwell. I can see a drip of water on the inside plate where the bolts go through to the bracket which now replaces the windscreen hinge.
Fortunately still under warranty so when the bad weather backs off, it will be a trip to the stealer.
The previous owner kept the Landie in a garage so I suspect he never realised there was a problem.
Post #394889 1st Feb 2015 6:31pm
Gleaney
Gentlemen. No leaks. It's like a submarine now Rolling with laughter Damn planet is short of Kryptonite !
Post #396835 7th Feb 2015 10:09pm
Page 2 of 2 <12
