- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Td5 > Crank pulley worn = bad vibes |
jonny2tanx
So I changed the pulley using one described as OEM and it stopped the chirp on start and switch off. However it did nothing for the vibration I was experiencing. I had a look today and put a screwdriver between the pulley and the damper and prised a bit and saw that the pulley moved slightly in relation to the front of the engine. I take it that this is not normal?
5th Jun 2015 6:45pm |
mk1collector
5th Jun 2015 10:32pm |
