![]() | Home > Technical > The MOT |
The trailer flashing light might be an issue if you have a 13pin towing elecric socket as that now falls into a testable item on the MoT. If you have a 7 pin socket, it's not a test item and you can come out with the imortal line "It's never done that before!" and the worst they can do is put an adisory on the paperwork.
It's the little things that when done make the testers life a little easier and help smooth the way such as if you have lap belts like the middle 2nd row seat put the belt in position so the tester hasn't got to hunt for it, same with the third row bench seats in the back if fitted. Take off the suction mounted phone holder and satnav brackets off the windscreen especially if they are in the 'swept' area. It can be a good plan to just give it a quick blast along a fast road to blow out the cobwebs and get to the testing station at least 10 minutes before your time slot. Giving it a quick blast will make sure that the engine is warm and all parts are moving freely. In all just take it in your stride, we all become nervous before the test much akin to being called up before the headmaster ![]() Good luck. |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Swivel joints are clear of oil or grease.
Tow bar if fitted is not rusted and plate is clean. ( I got an advisory a couple of years back as I had sprayed over the plate) No leaks from steering box. You could have a look here........http://www.motester.co.uk/mot-information-for-motorists/mot-test-checks-list Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 ![]() ![]() |
The socket is a 7 pin.
Interestingly the last owner had it looked into at the last service and the dealer reported no fault found. Although I think when I mentioned that last time on here someone pointed out it was possibly because we now had LED lights and it needed a specific relay. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic 2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed) |
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 334 ![]() ![]() ![]() |
The trailer light should flash once or twice when you indicate. If it is flashing all the time there may be a problem. |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
Speaking as an mot tester.
The 7 pin, 12 n socket is subject to a visual inspection only. The new 13 pin is fully tested. The trailer warning tell tail is NOT part of the test. As long as the indicators work and there respective tell tail lights work, they pass. If one light influences another lights operation. That`s a fail. I.E. looking for a ground. Excuse the spelling I`am better with spanners and wires. |
Well it passed.
Apparently there was a small amount of oil on a wheel bearing and there is a slight leak from the rear doff, but nothing that's dripping onto the ground. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic 2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed) |
Good one, allways a sigh of relief
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
Well done Catherine, that must be a bit of a relief for you... ![]() Although I am quite surprised it did not come with a full years MOT when you got it... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
NickH Member Since: 01 Nov 2014 Location: Halifax Posts: 204 ![]() ![]() ![]() |
Glad it passed CatherineF
Get the oil leak on the wheel bearing sorted, this means the hub oil seal has failed and when it gets worse (trust me it will!) the oil will contaminate the brake pads which is not good. Good luck ![]() 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
Apparently it needs new front pads in about 6K miles too. That would take it to around 45K. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1386 ![]() ![]() ![]() |
Are you a member of the Allegiance scheme? If you are, you can get discount on your servicing costs, and the MOT is normally free with the service. Euro-Leafing to infinity and beyond.....
No we aren't, how do we become members? 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
What's the likely cost of the hub seal and assuming it's a seal on the diff? 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Off the top of my head a hubseal is about 90p and diff seal a couple of quid
