Home > Maintenance & Modifications > Sump/Steering Guard
Page 2 of 3 <123>
Defender2014 wrote:
I picked up an Urban Truck one last week.
A good solid piece of steel in satin black, bolted up sweet in about 30 mins
I have a black UT one, that I fitted to my 110 in November, it's already had to be painted as it rusted so badly Evil or Very Mad
I'm not sure if it was painted, coated or coloured in with a felt tip pen, though I'm less than pleased with it.
Post #409406 20th Mar 2015 10:43pm
leeds
shaggydog wrote:
Quote:
There are lots of different makers and some are cheap as chips. I have some photos of what happens to the el cheapo version off ebay. Not pretty.
You can't say that and then NOT put up some photos Brendan Whistle
When you want to find that particular photo it can be difficult.
Will carry on looking but el cheapo rear bumperettes
Found it
Brendan
Post #409414 20th Mar 2015 11:15pm
HardCharger
Asides from weight issues, why go aluminum over a galvanized steel set up?
Also, are set ups with the removable plate bit but leave the mounts on better than set ups where you have to replace everything when you have to replace the plate bit?
Are these guards to be used with track rod guards or is it an either or proposition?
Post #409441 21st Mar 2015 4:40am
Either/or. The guards would clash.
I don't think there's any advantage of either bolt on, or bolt on brackets.
It should be a fit and forget item really.
Post #409446 21st Mar 2015 7:17am
LR90XS2011
I had a beautiful COR4 aluminium steering guard that fitted easily and was made to last (see the COR4 or EQUIPE web sites) however before you buy any guard consider what you want to use your defender for. Mine looked good but didn't have any recovery eyes, I wanted to use Jate rings and they would not fit with it.
Unless you are going to off road you are adding a load of weigh for nothing, if you want to seriously off road then you need one made for that not as a cosmetic addition, you also need to consider other items such as recovery points winches and steering dampers before you make your purchase as not everything fits together.
Cosmetically I think Jate rings make my 90 look more purposeful than the steering guard
 DEFENDER 90 TDCI XS,
Post #409447 21st Mar 2015 7:22am
K9F
I have an SVX steering guard that had done the rounds with two other forum members. When I upgraded to a bumper with recovery eyes it wouldn't fit so I took a disc cutter to it and shaved an inch off either side so it would. I then had it stripped and powdercoated black.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #409448 21st Mar 2015 8:30am
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Similarly, I had the SVX guard and it didn't fit with jate rings. I had a friend mill the plate so it did fit.
[/img]
Post #409486 21st Mar 2015 11:25am
I have still to find one that will fit with mine - I'm not sure why that is so hard. had a cracking setup on my old Disco from W&H Wheelcarriers.
I'd argue that they are also far more useful. Thumbs Up
Post #409488 21st Mar 2015 11:29am
Alive Tuning
kmac wrote:
Alive Tuning wrote:
Hi
Why not have a look at our Alive Steering Guard.
Hi you say: "This beautifully made guard is made from thick but lightweight solid Aluminium plate,"
How thick is that exactly in mm please?
Hi
Our Steering Guards are 6mm thick aluminum plate. They do the job the are designed for very well but also look the part.
Best Regards
Alex Divers Thumbs Up
Post #410172 23rd Mar 2015 3:20pm
Zeissman
United Kingdom 2009 Defender 110 Puma 2.4 HCPU Corris Grey
Hi How much are your guard?
Regards I don't think you understand, these boys killed my dog
I'm just a pecker wood who lives in the hills with too many guns and a land rover defender
Post #472748 15th Nov 2015 7:32pm
Alive Tuning
Hi
Our Steering Guard is £150 + Vat. Check it out through the link below.
http://www.alivetuning.com/product/defender-steering-guard/
If you need anything else dont hesitate to ask.
Post #473404 17th Nov 2015 10:42am
"The Alive Tuning Steering guard for the Land Rover Defender, not only giving protection to vital steering components, but also helping to direct the airstream beneath the axle, reducing the amount of MPG destroying drag when travelling at speed."
So do you have any figures for this?
Post #473444 17th Nov 2015 12:30pm
Alive Tuning
Hi
Our Steering Guard does effectively help direct the airstream in a more beneficial manner and we can prove this by using our Dyno fan and our smoke machine to show the path the air takes at 60mph wind speed. By a result of this it causes less drag which in turn increases MPG. This is fairly basic knowledge that less drag = more MPG.
If there is a demand we will be happy to set up this demonstration on our Dyno again to prove our point.
Post #473494 17th Nov 2015 2:33pm
jimbob7
I fitted the understated standard tubular steering guard,which is more than good enough for basic road kill/debris.Also good enough for the army.
|Painted with Rustoleum,and "waxoil'd" inside.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pov.spec,ftw. 2006, 110,TD5.
Post #473500 17th Nov 2015 3:10pm
LEZ
Okay Alive, what is the increase in mpg with your guard then ?
Post #473508 17th Nov 2015 3:29pm
Page 2 of 3 <123>
