Home > Technical > Rear Crossmember Torx bolts
Page 2 of 2 <12
donmacn
^^^ Is that really correct? I have them on my '94 Tdi SW.
I took the bench seats out of the back, and they certainly had nothing connecting them to those bolts. On mine they do line up with tabs on the crossmember/body rail. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #774086 20th May 2019 7:07pm
Djcla
Ok sussed it, I'll replace those then as I do have seats in back.
Post #774087 20th May 2019 7:08pm
They secure two large lumps of steel between the front face of the rear crossmember and the underside of the wheel boxes, which in turn are mounts for seat belt rails that run behind the rear seats. Darren
Post #774113 20th May 2019 8:40pm
donmacn
Just for the avoidance of doubt, I wasn't saying "I don't think so!" - more "really, I didn't know that." Poorly expressed on my part.
100% for sure though, my car had nothing like that when I got it. There is a steel plate underneath the top of each wheel arch, with a bolt coming through to the passenger compartment. I've always assumed this was for a seat belt rail - but while the seats were in the car when I got it, there were no seat belts - and nothing linking those plates I've mentioned to the cross member.
Is there a part no for this - just for interests sake. Donald
in the past..
Post #774131 20th May 2019 9:11pm
I don't have a part number but do have a picture:
This is looking up and towards the rear of the offside rear wing of my old TD5 110 station wagon. The bottom of the picture is the front face of the rear crossmember and the tubular bracket on the left spans from it up to the underside of the wheel box. The seatbelt rail is then bolted to it through the wheel box from above.
Hope that helps. Darren
Post #774143 20th May 2019 9:25pm
donmacn
Cool! Thanks very much. I recognise the picture perfectly. I was just in there putting 'gaskets between my crossmember tabs and the aluminium panel, and then refitting my Gwyn Lewis shields and stuff.
So I wonder now if my car - "utility' or " low line" station wagon ever had such a thing, or if it was removed at some stage before I got it. But I've learnt something about what it's all supposed to look like. Donald
in the past..
Post #774146 20th May 2019 9:33pm
jerseyman
Do people normally remove these Torx fasteners when doing a Crossmember tidy up?
Post #774149 20th May 2019 9:37pm
Djcla
I've looked at some of the after market bench seats online and not sure they come with the tubular bar etc that goes behind the seats. Maybe this is why some vehicles don't have them fitted. Unless there is an assumption you have the rest of the bits already.
Post #774169 21st May 2019 6:28am
Djcla
That's what I'm in process of doing at moment but one snapped and I couldn't work out what they were for. I'm going to order replacements today as they are clearly a critical safety measure.
Oh and they are a pig to remove
Post #774170 21st May 2019 6:30am
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Definitely soak them in penetrating fluid of some kind , two came out relatively easily and two snapped off . Turning a 10 minute job into two hours having to drill out and retap ! https://www.instagram.com/hustynminepark/
Post #774184 21st May 2019 8:38am
Djcla
The exhaust rubber bracket thing is in the way on one side, any tricks to get that off?
Post #774186 21st May 2019 8:50am
Djcla
is this what i need to replace these bolts and washers etc?
https://yrmit.co.uk/product/land-rover-def...ixing-kit/
Post #774189 21st May 2019 9:03am
Bluericky
They look like the ones .
The bolts above the crossmember are much shorter and equally irritating to remove https://www.instagram.com/hustynminepark/
Post #774202 21st May 2019 11:58am
Page 2 of 2 <12
