Home > Puma (Tdci) > location of coolant temperature sensor? |
TonoDef Member Since: 23 Jul 2014 Location: LILLE Posts: 14 |
Hello,
i believe it's Item 8 on this diagram ? Click image to enlarge [/img] |
20th Jan 2015 5:53pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1917 |
Hi thanks for the reply,
mine is a 2.4 and looks a different sensor, I've had a quick look in the dark this evening and believe its at the back of the engine in a right of a place to get to, looks like bonnet off time! 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
20th Jan 2015 6:17pm |
The 2.4 does not have a dedicated coolant temp sensor. It does have a CHT (Cylinder Head Temp) sensor located at the rear of the engine and it is a bit awkward to replace.
20th Jan 2015 7:05pm |
That's the one lorryman! Looks a pig of a job too! 2016 Range Rover Autobiography 4.4 TDV8
20th Jan 2015 7:25pm |
Workshop manual states:
1. Remove the engine cover. 2. Disconnect the cylinder head temperature (CHT) sensor. 3. Release the CHT sensor wiring harness. 4. Using the special tool, remove the CHT sensor. 1. To install, reverse the removal procedure. Tighten to 10 Nm (7 lb.ft). Special tool is Socket, CHT Sensor 303-680 and just looks like a mulipoint socket with a cutaway down one side. |
20th Jan 2015 9:02pm |
Thanks! Obviously the cut out is for the cable, Iam hoping there's enough room for a open end spanner! Or il have to cut the wires and use a rachet spanner!
20th Jan 2015 9:23pm |
Maybe a crows foot wrench would save you having to cut any wires or even a lambda sensor socket depending on what the actual size required is?
21st Jan 2015 10:22am |
good idea!
its a 10mm or 12mm, ive got a 22mm lamda/oxgen sensor socket sods law it will be different size 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
21st Jan 2015 11:56am |
Dont think it's anywhere near 22mm , while since i done one or looked at one , but think its about 16mm ( not 100% )
15mm |
21st Jan 2015 7:53pm |
Spot on it a 15mm 2016 Range Rover Autobiography 4.4 TDV8
21st Jan 2015 7:58pm |
Spot on its a 15mm 2016 Range Rover Autobiography 4.4 TDV8
