![]() | Home > Technical > td5 ignition and lock set |
martyp1970 Member Since: 21 Oct 2014 Location: Cramlington Posts: 40 ![]() ![]() ![]() |
http://www.ebay.co.uk/itm/161561040768?_tr...EBIDX%3AIT
Hi guys, just made a shocking discoveryon my 06 xs 110, my only 1 ignition key does not fit my drivers door and rear door barrels ???!!!!. So if my battery goes im up the creek. I have seen these on ebay and know I need the larger barrels because of the year it is. can someone verify this is the correct set I need. cheers |
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 ![]() ![]() |
Sp landrovers buddy- a lot cheaper iirc V8 90...WIP
Definitely not seized just wrong key !!!.
That sp landrovers have then at cheaper prices but all upto 2002 smaller handels and I have the larger ones I just wanted ignition and matching barrels . cheers |
I just swapped handles to the smaller ones they also sell. V8 90...WIP
Just ordered everything from sp plus smaller handle.
