Home > Td5 > Where to stop... (Anyone taken a Td5 engine out before?)
adseybear
Canada
I'm shortly going to be replacing the head on my Td5 with an AMC one after the infamous rising oil level.
However look at the other list of things to do, the clutch (will do flywheel as well) needs replacing, and I'm also aware the rear crank seal is peeing oil everywhere, which has led me to think down the lines of just taking the engine out...
Also for peace of mind it would allow me to pull the sump and see if running on contaminated oil has done any harm to the bottom end bearings.
Thoughts? 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #388646 15th Jan 2015 8:30am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
If you have the engine out and the head off why not check that too. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #388656 15th Jan 2015 8:44am
NickH
England 2003 Defender 90 Td5 PU Rimini Red
When my clutch goes I will definitely be taking the engine out, I will then re-thread the sump plug and replace the knackered sump gasket and any other jobs that would be a pain with it installed.
I dont think you will have harmed the bottom end, it also might be worth replacing the gearbox input seal whilst its out, they sometimes leak like mad, cost pennies to replace and its a quick and easy job. Thumbs Up 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #388779 15th Jan 2015 5:04pm
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
I've had the engine out a couple of times and it's no great shakes at all. Hardest thing is to get the bloody fan off!
Just make sure you have a decent engine hoist. Since you will be changing the flywheel and clutch, you may as well change the rear crank oil as you have to take the sump off to do it anyway.
I doubt you will have damaged the bottom end, unless you have been very unlucky. The Td5 bottom end is pretty rugged so hopefully you should be ok. Perhaps budget for a new radiator while you are at it, and you can forget about big items for a long while then!
Dave
Post #388906 15th Jan 2015 10:43pm
Fatboy Slim
Wales
Wouldn't bother pulling the sump off looking for debris- take the oil filter off, cut it open and look for any metal in the filter media. A couple of tiny flakes is ok but if it glitters or has white metal or copper in it it's time to investigate further.........
Post #388917 15th Jan 2015 11:18pm
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
I was the very unlucky one where the bottom end went Evil or Very Mad
Crankshaft had snapped in two pieces Shocked
Have had gear box out a couple of times, all doable with engine crane through door.
Also changed engine using same engine crane.
I was encouraged to have a go having never done anything like this before. It is surprising what you can do and the enjoy,ent you get from doing it yourself Thumbs Up
Post #388919 15th Jan 2015 11:35pm
amondeggs
Just for info the engine had done 205000 when it went bang 👍
Post #389301 17th Jan 2015 8:45am
adseybear
Canada
Onwards! Decided to take the engine out Wink 2003 Defender 90 Td5 CSW Belize Green - "Betty"
Post #398624 13th Feb 2015 10:47pm
NickMc
It's not too bad a job try doing the head/on the disco 2 with that stupid sound dealing and tunnel cover or as I like to call it the oil leak sponge Rolling Eyes
Post #399193 15th Feb 2015 11:07pm
adseybear
Canada
Maybe its a good thing we went on to check the bottom end...
Post #399724 17th Feb 2015 6:25pm
NickMc
Oh dear been washed/run on diesel too long? Was it cracked in the number two injector socket?
Post #399774 17th Feb 2015 7:36pm
Martin
Site Admin
Pah!
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #399780 17th Feb 2015 7:46pm
adseybear
Canada
Yeh, it's obviously had diesel in the oil too long, although nothing else is showing any signs of wear. Will pull the rest of the bearings and have a look. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
Post #399879 17th Feb 2015 10:27pm
