Home > Technical > Running up td5 odometer mileage?
g-mack
Ok just purchased set of td5 instruments for my 300tdi
I'm happy with how to wire it all in following retro anacondas how to guide. What I'm not sure how to do is adjust the mileage. There is a thread on lr4x4 showing a run up circuit but I don't really understand it, or have the tools to program a chip. Anyone done this recently?
I need to run up 110k My 109 thread
my youtube channel
Post #386321 8th Jan 2015 2:36pm
munch90
sorry but why bother to change the dash , whats different between 300 and td5 ?
sorry not knocking you , more the fact ive never bother to look what the difference's are ?
Post #386328 8th Jan 2015 3:03pm
gilarion
Why run up the mileage, just make a note of the present mileage on your old unit, there is nothing in law about changing your speedo odometer, it’s perfectly okay to change the odometer by replacing with a used unit. However, it is illegal to roll back or misrepresent the mileage without disclosing to a potential purchaser of your vehicle that the odometer has been changed. Keep your Mot’s to show any prospective purchaser in the future what you original mileage was.
Post #386341 8th Jan 2015 3:23pm
g-mack
munch, for me there is a HUGE difference, looks better, million % better illumination, smooth speedo, and illuminated heater controls!! Thumbs Up
gilarion, thats probably what i will do if i cant find a simple solution, but it would be nice to have it all correct ! My 109 thread
my youtube channel
Post #386347 8th Jan 2015 3:41pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
I've done this once for a friend who upgraded his 200Tdi dash to the Td5 dash Wink.
The difference in distance requested was something like 250k Mr. Green
So I designed a little electronic circuit to make this possible. I should stil have the hardware lying around.
Need to check this.
If you could point me to the thread on this other forum, perhaps I can help to explain ?
Sending over the odometer to Belgium will be a bit costly, otherwise I would be happy to do this for you. Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #386396 8th Jan 2015 5:38pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
G-mack I would love to update my dash, will do it one day. Best of luck
Post #386422 8th Jan 2015 6:16pm
g-mack
hi Peter,
this is thread http://forums.lr4x4.com/index.php?showtopic=69070e
im clueless when it comes to these things! apparently hitting it with a hammer wont work Rolling with laughter My 109 thread
my youtube channel
Post #386432 8th Jan 2015 6:41pm
g-mack
Post #386434 8th Jan 2015 6:41pm
gilarion
g-mack wrote:
hi Peter,
this is thread thhttp://forums.lr4x4.com/index.php?showtopic=69070e
To many t's andf h's
try this
Post #386439 8th Jan 2015 6:47pm
g-mack
thanks mate, don't know how i managed that! Thumbs Up My 109 thread
my youtube channel
Post #386440 8th Jan 2015 6:50pm
gilarion
No probs Smile
Though maybe this is easy for some, but not for me! Whistle
Right were do we start...... Firstly my appologies if this has already been covered in the forum and iv not seen it.
Im following in the footsteps of the retroanaconda and his good work on investigating installing TD5 instrumentation and Speedo into older defenders so you can see your gauges at night.
Only the speedo I got off ebay had 64k on it and my 90 has 97k. I like to keep things right so decided to up the mileage to 97k. Some dont bother, some take photos for the history of the vehicle. Others look and either say dont go out at night or if it aint broke dont fix it.
Some may even send there speedo to ETB instruments or digi dash or what ever they are called these days and pay to have the reading changed. (This is the only way I know of to have the mileage reduced)
Firstly the speedo transducer.... How do we replicate its signal... What does it do.
In short the "A" pin of the speedo transducer connects the signal wire from the speedo to earth 4 times per rev of the transducer. so one 360 of the transducer goes N/C earth N/C earth N/C earth N/C earth. this can be confirmed using a multi meter and putting it on beep test connecting one lead to earth and the other to the wire connected to the A pin and spinning the transducer in your hand. The transducer will need powering up for this.
I read else where in this forum that the transducer gives 4100 pulses per mile.
Iv read about people putting the end of a transducer in a drill to spin the mileage up which seems like a good idea untill you need to add more then a couple of thousand miles to it.
Knowing the the transducer connects the speedo to earth to pulse it mad my task easier as i had some components in my electronics draw that specialised in connecting things to earth. up to something daft like 34v and a fair few milliamps. I also had a PIC Micro controller and an EASYPIC 6 development board. so i wrote a small program to turn on and off a pin on the pic chip about every 7 milliseconds which i worked out should be about 120mph on the speedo.
My code in Mikrobasic for pic
Program Speedo
main:
ANSEL = 0 ' configure AN pins as digital I/O
ANSELH = 0
TRISC = 0 ' set PORTC to be output
PORTC = 0xAA
portC = 0
while true
PortC.0 = 1
delay_ms(1)
portC.0 = 0
delay_ms(2)
wend
end.
Now in the above code the ms delays are less then 7ms and the reason is because when i powered it all up the speedo showed less then 50mph. I put this down to me running the chip with its internal clock rather then a 8 or so mhz oscillator which would be more accurate. anyway the above settings give just over 120mph. This should give me my desired mileage in a week or so. (im not in any rush)
The components you will need to make this circuit are....
1x PIC16F887 ebay or maplins
1x ULN2803 (18pin chip) ebay
1x tripad board from maplins
oh maybe some connectors if you intend to make it re usable... there again you could solder your link wires directly to the board it wouldnt make alot of difference.I run this from a power supply that gives out 5v and 12v. if you dont have one of these look at adding a "7805 voltage
Rolling Eyes Rolling Eyes Rolling Eyes Rolling Eyes
Post #386472 8th Jan 2015 7:33pm
shaggydog
Out of interest what existing dials do you have?
Are you planning on keeping them or transferring them over? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #386477 8th Jan 2015 7:42pm
Retroanaconda
The mileage is fairly easy to change if you have access to an EEPROM reader wotsit. PM Cwazywabbit on the LR4x4 forum, he has changed many speedos for people.
You can clock on the speedo with a circuit or micro controller but it takes ages as above.
Post #386490 8th Jan 2015 7:58pm
g-mack
shaggy, im replacing complete instrument binnacle. so speedo, fuel, temp, clock, warning lamps My 109 thread
my youtube channel
Post #386491 8th Jan 2015 7:59pm
g-mack
Problem solved!! Found someone to do it for a nominal fee! My 109 thread
my youtube channel
Post #386551 8th Jan 2015 9:47pm
