Home > Puma (Tdci) > Oil pump question
Page 4 of 6 <123456>
spudfan
Ireland
So whatever the ins and outs of it, more frequent oil and filter changes would appear to be the norm - as in preventive maintenance. I suppose the question is "How frequent should the changes be for the average owner?"
I wonder if the Defender replacement will have similar issues engine wise? Emission laws are only going to get stricter. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #408642 18th Mar 2015 12:40pm
Are people choosing to ignore the oil service message that should be generated by the dpf software or is the calculation it uses flawed?
The threshold (fuel being 7% of engine oil volume) would suggest nearly 1/2 litre of diesel in the sump (based on 7 litres of oil for a oil & filter change). That's a significant increase on the dipstick assuming it's still a linear scale above the full mark.
Post #408647 18th Mar 2015 12:54pm
The management system has no way of knowing how much oil dilution has actually taken place - it isn't sampling the lubricant.
The oil service message is really a "best guess" based on driving style and nothing else.
Post #408659 18th Mar 2015 2:09pm
It's a little more than just driving style - the calculation includes the frequency and length of each active regeneration. So for it to calculate any percentage, it must have some values for the volume of fuel used and how much is expected to end up in the sump.
It would seem sensible for that calculation to err on the conservative side.
I would just be interested to know what these values were. I guesstimated 1.89 litres of diesel per active regeneration.
Post #408680 18th Mar 2015 3:40pm
Juhulia
2012 Defender 110 Puma 2.2 SW Keswick Green
According to my dealer the 'OIL SERVICE' sign does simply count milleage and time.
From these data it "calculates" the necessity of an oil service according to the service intervalls that are well-known.
A job any 5 year old child could also do.
The sign does not indicate things like 'Diesel Oil Penetration Rate' or 'DPF fillement ratio' or whatever you guys are guessing.
Best - Julia
Post #409551 21st Mar 2015 2:44pm
munch90
sorry but why worry what makes the light come on
when it does come on just change oil and filter
Post #409552 21st Mar 2015 2:48pm
Happyoldgit
...then reset the notification. Steve.
http://forums.lr4x4.com
Post #409759 21st Mar 2015 11:27pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
Changed my oil at 6,000 miles as the oil appeared to be very black and appeared to be thickening
I have now covered 3,000 miles on the new oil and have 9,000 miles on the clock - the oil change warning as yet has not come on and next oil change will be at 12,000 miles where the vehicle will be 1yr old (doing approx 12,000 miles a year)
It will be intering to see if the oil change warning does come up as I did not reset it when I changed the oil at 6,000 miles
I do a fast run to work of 32miles each way along the M4 and A465, my DPF only does an occasional chuck.
Question
I thought the longer the run the better for cleaning out the DPF, I thought it was the short runs that caused the DPF to block up?
Post #409787 22nd Mar 2015 8:32am
munch90
I don't think long or short runs make any difference to dpf UNTIL it wants to regen then you need a long run for it to start and finish the regen
its the starting to regen and not finishing the process is more the problem and when you can get the diesel in oil more,
all short runs mean it may start regen and cant finish because you stop then next short run it starts process again and cant stop because you stop and so on
on a short run im guessing there would be more tickover stops and starts etc allowing diesel passed rings and in to oil
I know when doing a forced regen you need to keep speed and revs up for the scanner to keep the process going which sometimes when there is a bit of traffic about is hard to do
Post #409790 22nd Mar 2015 8:51am
Iktank
Thanks for that Thumbs Up
Im a firm believer in frequent oil changes and looking at the state of the oil earlier in the thread it is understandable why the pump/engine would fail with oil in such condition.
My Audi meant to have long life service - 20,000 miles i do oil every year or 8,000 miles
Hilux mk4 (15yrs old) oil changed every 5,000 miles (run semi synthetic 10w40) instead of 6,000 miles which was based on lower spec mineral oil
Will change oil on Landy every 6000 miles, i have found the Millers xf C1 to be well priced, normally always use Catrol but it is very hard to get Exclamation
Remap shortly and may consider DPF remove, know it wont pass MOT chance I will take as I intend on hanging onto the Landy
Post #409795 22nd Mar 2015 9:12am
Best - Julia
According to dealer - not the best start to making a statement of fact Whistle
I quoted from the workshop manual, if you'd like to ask said dealer which part of manual needs correction?
Talking Censored is in their job description, isn't it?
Post #409819 22nd Mar 2015 10:52am
Worry would be the wrong description.
Keen to understand how & why things work. If you are happy to not know how to raise the bonnet then that's fine move on & let those that do ask questions and learn new things.
Post #409821 22nd Mar 2015 11:02am
GEllis
England 2013 Defender 110 Puma 2.2 USW Indus Silver
How can you tell when the regeneration process starts?
I only recently had one of my 2.2 defender engine replaced under warranty with 64k miles due to oil pump failure.
Post #409825 22nd Mar 2015 11:14am
munch90
ok been opening bonnets all my life
it knows when to regen not by miles , not by driving style , not by how many oil changes its had , not by trip length , it knows by the difference pressure before and after dpf and ecm calculates how blocked the dpf is
if you look at the dpf there is a small stainless pipe comes off the top and bottom of the dpf that run up to a valve that tells ecm the pressure difference
for oil service light to come on its normally a mixture of time running and miles and maybe dpf regens done , some cars have a oil level as well so if level is up after regens it tells you to change it . normally ( well all the ones ive seen is the oil gets thinner with diesel , I think some people think it gets thicker with carbon due to having a dpf , it cant as carbon is stored in dpf ready to be burnt at a high temp in regen and turned to ash ) oil gets thick due to not being changed
I don't believe in changing oil too regular , I don't believe new oil to be a better lubicatant and also your doubling the time in a engines life that there is no oil circulating and what is is full of air bubbles , I think oil gets better with use ( BUT not over use )
I don't believe in 20,000 mile oil changes , once a year or 8-10k is ok depending on conditions , modern diesels run cleaner less cr@p in oil , modern diesels have lower compression , modern diesels are built with better machining and better metals , run better oils , so why change oil more
I don't believe the more expensive the oil the better
more the problem with modern synthetic oils is how they effect plastic and rubber in the engine , making o rings hard , making oil seals hard , filters hard , this was one of the main problems with the k series headgasket problem the gasket used rubber seals and I think the oil makes the seals hard
by my other post about why worry is some people will never understand the mechanics of a engine ( not pointing finger at anyone ) , in the same way I will never understand other peoples trade
different things for different people my mate has two sons , one lorry mechanic and a good one , rides motorbike etc , the other one a a Michelin star chef and a good one , stuggles to fill his car with petrol , cant even change a fuse , falls off a bike within 10 ft , he will never understand mechanic's but give him a bit of meat and few vegs and your sorted !
that's all I ment by post
Post #409836 22nd Mar 2015 11:43am
munch90
I don't think regen has any effect on oil pump failure
how do you know when it regens ? be honest I don't really know , guessing maybe smell of higher temp in exhaust , fitting temp gauge to exhaust , a light would be handy but a light makes most people panick , as said most don't need to worry as if everything is working right it will do it and you don't need to know , general advise seems to be if you only do short runs you need to gave them a run up the motorway every now and then , when it needs a run is anyone's guess !
as with anything im not a expert on tdci engines only what I think happens !!!! , you treat your car and engine as you think is best
Post #409844 22nd Mar 2015 12:02pm
