Home > In Car Electronics > Td5 headlight leveling switch for wiper intermittent ?
boode
England 2003 Defender 90 Td5 HT Rutland Red
The headlight leveling switch has 4 positions - could it be used to control a relay with 4 time intervals for the wipers ?
The intermittent could then be speeded up as rain fell heavier/drove faster and slowed easilly
I know it can be controlled by the relay that lets you set the exact delay, but that would need constant re setting as conditions changed
A simple switch would be easier.
I dont have the switch so do not know how it works - any ideas would be appreciated
Post #383244 29th Dec 2014 10:55pm
dgardel
Italy
why not this solution?
http://1drv.ms/13FGdvl Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #383272 30th Dec 2014 12:12am
dgardel
Italy
opsss Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #383273 30th Dec 2014 12:15am
Anderzander
I dont know about the switch -but I do know that nothing could be easier than setting the timing interval on the 99 wiper relay.
It might sounds awkward - but I practice it's very intuitive, the stalk is at hand without having to reach across the dash as you would on your solution.
It works like this - rain starts to build, flick the switch on and off - wait until it's built up again and flick the switch back on again. Then that's it the interval is set to the rate the rain builds up.
Even with 4 setting it'd either be too fast or too slow. For the ease of fitting one Id try it before you get into a more complex solution ....
Post #383286 30th Dec 2014 7:48am
boode
Thanks Anderzander - quick question
Once the 99 relay is set and it starts raining heavier - how do you decrease the time delay ?
The 99 relay would be easier, but as you say it does sound awkward
Post #383364 30th Dec 2014 2:42pm
Tiger
The 99 relay works as thus....
when it rains fluck the int switch down to clear the screen but don't leave it down. When enough water has acumalted on the screen to need it clearing again flick it down and leave it down.
It will then wipe the screen at the same intervals.
Not awkward at all very easy and a brilliant mod for £10 Thumbs Up
If you want to change the time repeat the above
Post #383368 30th Dec 2014 3:02pm
Anderzander
It times the off period from having been off - so when the rain changes you'd just knock it off - wait until it's built up on the screen again - and then knock it on, it will be set to the new interval.
Easy Peasy Smile
Give it a go.
Post #383369 30th Dec 2014 3:03pm
boode
That is easy - thanks
Although I thought they were about £38 from MUD not £10
Post #383377 30th Dec 2014 3:34pm
Anderzander
I bought 2 both from ebay at around £10 each.
Post #383388 30th Dec 2014 4:21pm
