Home > Maintenance & Modifications > Twin Battery System |
Andyred90 Member Since: 30 Mar 2013 Location: Wantage Posts: 482 |
You can fit slightly higher batteries with the flat dog tray but the box needs a little modification.
The clamp nearest the rear bulkhead is the issues so I changed the M6 threaded rod to an M8 then cut a small section of the rear lip away so you can access the strap and retaining nut. Will upload a picture later but Ive now got two Exides under the seat. My batteries are L317mm W175mm H175mm |
1st Feb 2015 2:29pm |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Now just to finish wiring in the VSR then a tidy up. |
1st Feb 2015 2:42pm |
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 746 |
Ive got twin PC1500's fitted onto a D44 tray. No clearance issues..
1st Feb 2015 7:04pm |
GreigP Member Since: 13 Apr 2014 Location: aberdeenshire Posts: 18 |
likewise..I also have twin PC1500's with the D44 tray... No issues
1st Feb 2015 8:22pm |
