Home > Other Site Sponsors > Uprated Paddle Clutch for 2.2 and 2.4 Tdci Defender
Porny
Site Sponsor
It has taken a while to find a supplier to work with that actually delivers what I want with back up....
But irb developments now have a direct replacement HD paddle clutch for all Tdci Powered Defenders
40% uprated over standard, but pedal feel and effort required remains almost completely unchanged.
Ideal for tuned Defenders.
£350 + vat
Paddle on left - standard right.
 IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #379979 18th Dec 2014 3:08pm
jst
great idea Porny - as in to supply one to us all, for those not on Face Ache, any chance of more info on the 3Ltdv6? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #380058 18th Dec 2014 7:54pm
Porny
Site Sponsor
Hi James,
Face Ache is a great social media, but I agree not everyone likes it. Although you can access my page without signing up.
The 3.0Tdv6 is getting there and there will be updates in the New Year... a lot of time (more than planned) has also been taken up by my 2.4 (and it's upgrades).
Ian IRB
Post #380246 19th Dec 2014 12:43pm
Ian,
For the benefit of those of us who are not clutch experts, can you outline the advantages of a paddle clutch (I imagine that the name refers to the fact that the friction material is discontinuous?) compared to a normal type?
I notice that the springs on the driven plate are shorter and appear to be much less likely to take on a permanent set and fall out. Does this mean that this is a suitable replacement for the standard clutch on all Defenders, or is it really only appropriate on fire-breathing tuned monsters?
Thanks,
Roger
Post #380266 19th Dec 2014 2:39pm
Skeggy 90
England 2011 Defender 130 Puma 2.4 SW Bali Blue
Just out of interest, what engine management are you running on the TDV6, if you can get a 3.0 to run as well in a Defender as a Disco 4 I would be very interested in a conversion. 90 300 TDI SW (sold)
130 TD5 Utility (Foley SV) (sold)
110 TD5 Hardtop (sold)
110 TDCI Utility (sold)
1st Edition Range Rover Sport Supercharged
Velar P380 HSE
Discovery 1 V8 auto
Puma 130 Double Cab (sold)
R35 GTR
Defender 110 300 TDI CSW (sold)
2010 110 XS Utility
Post #380305 19th Dec 2014 6:08pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Nice one Ian bout time someone has lookeed into the puma clutch as it has always been a problem
Thumbs Up
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #380490 20th Dec 2014 6:21pm
Porny
Site Sponsor
blackwolf wrote:
Ian,
Thanks,
Roger
Apologies - I hadn't noticed the other replies...
The advantages (due to both the design and material used) is the higher clamping loads and frictional co-efficient of the friction material. It is designed to be suitable for upto 40 % increases in torque over the standard clutch.
The springs are much shorter than a standard centre (is a HD centre pack) and are capable of taking a higher shock loading.
The downside of a full race paddle clutch is its aggressive nature... however, due to the number of pads/paddles used on this one (full race typically has 4 pads) - when fitted it is virtually no different to drive than a standard vehicle. There may be a slight increase in noise at idle (when clutch not depressed) - but apart from that, no other downsides.
It is suitable for all applications - from mild to wild... although if you go really mad then there is another option.... but will see how long this ones lasts first on my Puma (200bhp/565Nm... well that is what it used to make).
This clutch would be ideal for an IRB450 upgrade (so 450nm).... but equally at home on a standard vehicle that is worked hard.
Its took a while but we have an aftermarket ecu that is actually capable of running the engine properly and will also allow proper integration with an auto gearbox if needed.
A few people have tried using a UK offered standalone ECU - but from experience, the ECU capability is about 30 years out of date... and can not run a Tdv6 properly, and would more at home on a lawn mower. I ended up give a UK vehicle builder their car back with this ECU as I would not put my name to it. Cold start control was shocking, turbo control shocking and fault detection none existent.
The ECU we have finally sourced has almost as much capability as the OEM Bosch ECU... and will be calibrated so that is drives as well (actually better) than a standard TDV6 - and will definitely not have the dip in power/torque that you see on the Disco 4 when running on a rolling road (due to turbo switching/control)... and low speed pick up with hugely different - i.e it actually pulls away when you give it boot full pulling out at islands etc.
By the looks of it there will be 3x 3.0 Tdv6 builds on going this year - and one in a very special none LR application.
Ian IRB
Post #385915 7th Jan 2015 2:04pm
willyj
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Im starting to get the clutch rattle, got 58k miles on it and i tow alot. (MY11 2.4tdci 90)
Would this be an upgrade suitable for my use?
Cheers wil
Post #385918 7th Jan 2015 2:10pm
Porny
Site Sponsor
Hi Will,
Yes - would be a good upgrade.
Regards
Ian IRB
Post #385969 7th Jan 2015 4:13pm
theorangebandit
I always struggle with your site. Can you link a means to purchase this clutch kit please? My rattley puma is starting to do my nut in and this year its complete transmission over haul. Including the new gearbox output spigot upgrade 😃
Post #419246 26th Apr 2015 7:24pm
Caterham
I understand there may be a queue but I'm hoping to be the first to provide feedback on the new clutch Very Happy (please Ian - me me me.....)
clutch has been getting worse recently and noises have been diagnosed as such.....
I'm just hoping all the shocking gear changes as a result of the clutch (not me Whistle ) haven't caused any / too problems with the rest of the transmission.
will keep posted. Thumbs Up
Post #419294 26th Apr 2015 9:45pm
Pickles
Porny wrote:
blackwolf wrote:
Ian,
Thanks,
Roger
Ian
Looking forward to full details & pics of your TDV6 conversion in a Defender.
Pickles.
Post #419315 26th Apr 2015 11:30pm
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Ian,
You have had several emails.
Rob
Post #419485 27th Apr 2015 5:06pm
Lorryman100
^^^Ditto^^^ Including Facebook messages from myself and a few members on Angry Pumas.
Post #419587 27th Apr 2015 8:35pm
theorangebandit
pleeeeeease can i get a link for this clutch!!!???
Post #422352 10th May 2015 10:50am
