Home > Td5 > Temperature
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
Temperature
My temperature gauge has never worked and no matter how I am driving it never moves. Do I need a new sender unit ? Is that possibly the problem ?
http://www.ebay.co.uk/itm/Land-Rover-Defen...1555459956
Dunk
Post #378842 14th Dec 2014 9:46am
Could be the guage itself..
Not sure if the plug is the same as the fuel guage one.... try swaping them over and see if the fuel guage moves instead, could eliminate it.
Post #378856 14th Dec 2014 10:07am
landy andy
When you say it doesnt work, what do you mean? It just stays at the bottom and needle never moves? Or always just sits at half way?
Staying at half way is normal, then if it ever goes above it just goes straight into the red putting engine in limp mode.
If no move at all have you tried just shorting the cable to the sender and seeing if gauge moves?
Andy
Post #378859 14th Dec 2014 10:28am
Tank
Sits at the bottom and doesn't move ! Will try and short it and swap with fuel gauge as well ?
Post #378930 14th Dec 2014 4:46pm
GreigP
Scotland 1999 Defender 90 2.5 TD CSW Oslo Blue
you could always take out the sender unit and dip it in hot water vs when its cold.. stick a multimeter on it and see if its playing as expected .....
I had an issue with having the wrong ECU so my temp gauge worked in reverse... I'd already replaced the sender before checking the forum... doh!!
Post #378939 14th Dec 2014 5:13pm
MadTom
In TD5 the sensor is connected to engine ECU, and output of the ECU is connected to gauge. With nanocom you can test the sensor - ECU will show you the engine temperature, and also check the gauge. Do it before changing any parts.
In case the engine ECU is configured for Discovery2, instead of Defender, the temperature gauge works in reverse, not a big problem, but the throttle works much worse - wery sensitive on the beginning, and it makse the ride not comfortable. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #379233 15th Dec 2014 5:21pm
Tank
Mmmm don't have a nanocom Sad
Post #379326 15th Dec 2014 10:35pm
