![]() | Home > Td5 > Battery selection |
May help....
![]() http://www.defender2.net/forum/topic29701.html?highlight=optima http://www.defender2.net/forum/topic26702.html?highlight=optima If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 ![]() |
When mine goes I'll be fitting a Bosch or Yuasa,the oem ones a very good tho.
5 yr guarantee on (900 amp)Yuasa Pov.spec,ftw. 2006, 110,TD5. |
My nearly ten year old 90's still running on it's second OEM battery.
What's the point of spending three times the amount of the OEM one on an Odyssey when the OEM one does a good job and lasts?
The Odyssey has a high CCA for its capacity but it's not like you need to save every last inch of space in the battery box and if you accidentally leave your lights one then you may be thankful of the extra Ah you get out of the standard one. Someone at work has just got a decent branded (I think it's a Varta, that what they usually supply and he said it had a 5 year warranty) battery for his TD5 from our local auto electrical place for £70 including VAT. Unless you've got some particularly good reason to have something else, that's what I'd do. |
My 90 is running on a Optima yellow top. I have a winch and I use it too. The Optima is about 10 years old and has problems starting my 90 if it has been standing still 4 weeks or longer. Shorter periods not a problem yet. Roel
