- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Devon-Rover
The 2.2 has an intank pump so there isn't any worry about there being an air lock causing a major headache.
Just remove the old and replace with new one that has been prefilled and flick the ignition and you'll hear the pump purge what small amount of air is left, then start as normal.
It was the 2.4 that only has a sender so there was the worry about air locking or using a priming bulb to pull the fresh fuel through to the rail.
16th Jul 2017 10:28am |
