Home > In Car Electronics > Heated seat switch |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6612 |
Hi Phil, started a new thread for you as it's about switches rather than wiring.
I'm not aware of any three position (off/on/on) original type switch which could be used. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
2nd Dec 2014 11:23am |
Some info here about using factory switches, but only with one heat setting.
http://www.defender2.net/forum/topic23580.html 1988 90 Td5 NAS soft top 2015 D90 XS SW |
2nd Dec 2014 11:28am |
PumaPhil Member Since: 26 Oct 2014 Location: Bridgend Posts: 201 |
Thanks Martin, I might try to mount the little round switches supplied into the blanks where the factory seat switches would be. I would like to avoid any extra holes drilled in the dash!
2nd Dec 2014 11:38am |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Phil, here's what I did.
I used both I used the OE switch to switch the relay on the Weaco kit. I then left the round switches in the circuit but hid them away. I leave them on P2 as I find P1 a bit pathetic. I can always change the heat setting if I wanted but find leaving them hidden away and on P2 and switchged form the OE switch just fine |
2nd Dec 2014 12:05pm |
If you say that P1 is a waste of time, then I suppose I could just wire the P2 circuit into a OE switch. Got a few options to think about now...
2nd Dec 2014 1:23pm |
