Home > In Car Electronics > wiring colour |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6612 |
12V permanent or 12V ignition switched? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
29th Nov 2014 9:47pm |
Mcmuffin Member Since: 01 Apr 2014 Location: Antwerp city Posts: 38 |
ignition switched
29th Nov 2014 9:49pm |
White with a green stripe 1988 90 Td5 NAS soft top
2015 D90 XS SW |
29th Nov 2014 9:50pm |
However I don't think on an 08 Puma that there is one under the seat 1988 90 Td5 NAS soft top
2015 D90 XS SW |
29th Nov 2014 9:51pm |
some relais an fuses there and lots of cables
29th Nov 2014 9:55pm |
I mean I don't think there is a white/green ignition 12V there. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
I'll check tomorrow. If not, I make a connection to the cigarette lighter.
Kris |
29th Nov 2014 9:59pm |
Mcmuffin,
If the link works and you can read a wiring diagram you will have everything you need here, it's a rhd set but it'll be the same colours: http://api.viglink.com/api/click?format=go...%3Bwdo%3D1 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
30th Nov 2014 9:13am |
thx
30th Nov 2014 1:48pm |
Vince VDB Member Since: 17 Nov 2014 Location: Champagne sur Oise Posts: 60 |
Yes there is one under the seat. The brown/orange cables with a 15A blue fuse is 12V ignition. Very simple to find, there is only one cable with a single fuse integrated in the loom. I think this cable brings 12V to run EGR motor, because there is 12V during 5-6 seconds after switch off ignition. This is the brown/orange cable with the white strip. on top of the pic Click image to enlarge on bottom of the pic Click image to enlarge Defender 110 Puma 2.4 SW SE Defender 90 300 Tdi SW with TD5 body Land 90 V8 HT |
30th Nov 2014 2:36pm |
