Home > Technical > New security device
Lorryman100
New security device
An interesting new security device coming soon from Spinney engineering.
https://www.facebook.com/video.php?v=682130185230623&fref=nf
Post #374451 27th Nov 2014 12:02am
Looks good, reported to be �600
I'd like to see one fitted to a truck
Post #374477 27th Nov 2014 7:49am
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
Looks like a good bit of kit, I saw people on facebook complaining that if you took the rear prop off that they could still take the defender, this is true but it's in-keeping with the "layered" approach. It isn't a 10 second job to take off a prop, especially when you can't roll the truck around to get at the bolts. As has been said many times before on here and other forums, if they want it badly enough they will take it, our job is just to slow them down enough for it to not be worth the risk.
My only hope is that the key has to be inserted to activate the lock. Wouldn't want to knock that with your leg at 70 on the motorway. Shocked
Subject to a bit more information I'll look into getting one of these. Although �600 is a bit spendy! Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #374491 27th Nov 2014 8:38am
ericvv
Post #374502 27th Nov 2014 9:30am
Lock fits through a hole you have to drill in the upright of the drivers seat box:
http://www.fwi.co.uk/machinery/rat-trap-ma...-pinch.htm
Post #374522 27th Nov 2014 10:27am
K9F
If they can get it Thatcham approved it may bring an insurance discount that would perhaps offset the high cost. It appears from Lorryman's facebook link that this may be the route they are taking. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #374526 27th Nov 2014 10:32am
Surely you could just [do something very simple and quick] and drive off with the device locked? OK, it will be [peculiar to drive] since [there'll be something odd about it] but it will still be drivable.
Editted to remove details.
Post #374555 27th Nov 2014 11:50am
munch90
just use a hiab , just use a tilt n slide , just use a disc cutter , just use 20x Geoff capes's to carry it away , the list can go on and on . it boils down to if yours has it and someone else's doesn't yours is more secure
couple of things I would like to know , will it unlock if there is a load on it like parked pointing down or up a hill , how do you get at it to unlock / lock
Post #374561 27th Nov 2014 12:31pm
Agreed, as part of a layered approach it looks great, and particularly so because it is convenient in operation (and there isn't a hindredweight of steel rattling around loose in the cab when you're driving).
Post #374562 27th Nov 2014 12:36pm
Cupboard
you can always take the load off it if it won't unlock with load on. Just wobble it on the clutch like you have to wobble the steering wheel to get the steering lock off on a car.
Post #374563 27th Nov 2014 12:40pm
Here's a fuller picture of the Rat Trap - looks like it replaces the transmission brake back plate:
but still no full explanation of what it is locking and how? Does it just stop the drum brake shoes from being released?
Post #374769 28th Nov 2014 9:32am
looks like it's just welded to a standard back plate to me.
Post #374778 28th Nov 2014 10:26am
munch90
it locks the drum not the shoes by the look of it on the video
yes welded to standard backplate , will be done on a exchange basis maybe
how you get at it to lock it , I would like to know ( don't really know why I want to know as I have disc and no drum anyway so not much good to me anyway Rolling with laughter )
Post #374779 28th Nov 2014 10:27am
Lorryman100
Post #374890 28th Nov 2014 7:31pm
newhue
Australia
hmm I don't like the price, but having just dealt with insurance companies I can cope it. I also like that it's in position, not something floating around to become a possible projectile or taking up space.
I'm still curious if it can be unlocked under load however, or even engaged without more than the standard hand brake surge. My Defender and travels
Post #374894 28th Nov 2014 7:52pm
