Home > Technical > Wrong cap? |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 |
Today when I topped up the expansion tank with coolant I noticed that the coolant cap was a bit odd. The o-ring on the cap has nothing to seal against in the tank - see picture.
Also when I squeezed the top hose you could hear air escaping through the cap. I have not noticed this before and I have had the car now for a year and a half and I have topped up with coolant 3-4 times. Is it the wrong cap or is something missing in the tank? I guess the engine is running too cold if the cap is not tight? If it is wrong cap - what is the correct part No? My defender is TD5, MY 2004. Click image to enlarge Last edited by HansT on 26th Nov 2014 5:40pm. Edited 1 time in total |
26th Nov 2014 4:48pm |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 327 |
TD5 and TDCi indeed share the same cap PCD100160
26th Nov 2014 5:11pm |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 |
The colour of the cap is either yellow or black depending on the manufacturer. The one in the photo is not correct design. The part number is PCD100160.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20559 |
Yellow normally signifies Britpart. Blue Bearmach.
Neither would be of much interest to me. |
26th Nov 2014 5:18pm |
michaelwl Member Since: 19 Nov 2014 Location: Durban Posts: 65 |
Genuine LR one is black PCD100160 2002 110 TD5 White
1981 S3 R6 Matt Green - Now used as game viewer 2013 Discovery 4 XS |
26th Nov 2014 6:01pm |
Thank you very much guys for this information. I will order the correct cap from one of the sponsors
Do you think that fitting a correct cap will also improve the cab heating performance? |
26th Nov 2014 6:33pm |
What heating performance. 2002 110 TD5 White
26th Nov 2014 6:35pm |
I know that in Johannesburg you do not have to worry that much about cab heating but here in Sweden it is another matter
I have fitted electrical block heater, electrical and diesel cab heaters and maybe it was enough to replace radiator cap |
26th Nov 2014 6:46pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Might be worth giving your Heater Matrix a good flush through with a hose and checking your heater control cables are set up properly.
Early defenders can have very good heaters- as long as they are set up and looked after properly. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
26th Nov 2014 7:03pm |
110MGD Member Since: 17 Oct 2013 Location: Wear Valley Posts: 153 |
It hasn't been unknown for older caps seals to wither with age, and not form a seal around the top... I was thinking of cracked heads and allsorts due to overpressurizing etc etc. . So bought a new cap for about £6.00 - hundreds of miles have now been done, not even a dribble around the top! Job done! 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate 2014 VW UP! 2x D3 and 1x D4 GONE |
26th Nov 2014 7:16pm |
