Home > Puma (Tdci) > Genuine Land Rover Driving Lamps
Grockle
Hi,
Can some one help regarding the above, the switch has lost it's feed, I can't find any info in the hand book re fuse or relay location.
Thanks in advance. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #373201 21st Nov 2014 7:44am
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
If its been fitted as the instructions, the relay and fuse are in the passenger seatbox near the battery. The feed to the switch is from the rear of the instrument panel.
Borrowed from MartinK's gallery https://www.defender2.net/gallery/albums/u...ctions.pdf
Post #373207 21st Nov 2014 8:22am
Grockle
Thanks very much FH Thumbs Up 2.4 90 XS
Post #373220 21st Nov 2014 9:39am
Grockle
Genuine Land Rover Driving Lammps episode 2
Hi,
I have rung my LR dealer who tell me I must buy the whole lamp kit to obtain the relay ! can anyone help with the part number of the relay please.
Thanks 2.4 90 XS
Post #373227 21st Nov 2014 10:31am
Martin
Site Admin
Have you got a photo or part number from the relay?
As is normal, computer says no at a parts department. The good ones who make the effort are few and far between.
It is highly likely to be just a normal 30A or 40A automotive relay Rolling Eyes  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #373231 21st Nov 2014 10:45am
Grockle
Thanks Martin,
I'll have a look 2.4 90 XS
Post #373235 21st Nov 2014 11:13am
Martin
Site Admin
If you want to do a swap of another one to eliminate the relay as the fault, then you can use the electric window relay. It's a normal relay Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #373250 21st Nov 2014 11:39am
Fifth Horseman
Indeed a normal relay, aka YWB500060 @ about £3.80 will do the job.
Post #373258 21st Nov 2014 12:03pm
Martin
Site Admin
Not special to LR either, no need for a trip to a dealer.
Any motor factors (even Halfords!) will stock a standard relay Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #373259 21st Nov 2014 12:04pm
Grockle
sorry forgot to ask ,I can't see a fuse in the fitting kit instrictions, where is it ? 2.4 90 XS
Post #373275 21st Nov 2014 12:28pm
Martin
Site Admin
On the side of the relay holder.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #373276 21st Nov 2014 12:28pm
Grockle
Thanks Martin and FH for responding so quickly 2.4 90 XS
Post #373282 21st Nov 2014 12:38pm
Grockle
it was the relay which had corroded inside. 2.4 90 XS
Post #373921 24th Nov 2014 2:24pm
Martin
Site Admin
Great, did you swap it for another to test or just buy a new one?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #373923 24th Nov 2014 2:25pm
Grockle
Hi Martin,
Both,swopped it for the Yellow one which is near to it, then fitted a new one YWB500060 £4.60 trade price.
Thanks again,
Roger (Grockle) 2.4 90 XS
Post #373945 24th Nov 2014 4:41pm
