![]() | Home > Technical > Tow hitch query |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5889 ![]() ![]() ![]() |
Do you mean just replace the current tow hitch with say something like a Dixon Bate hitch? 1999 Defender TD5 110
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
I would love to use a tow step,, but also need to have the tow hight lower / adjustable
So use a gen slider tow bracket ![]() But would not want to be towing up to the 110 weight limits with that bolted to a tow step,, even with the extra chassis stays California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
If you mean this
![]() try here http://www.defender2.net/forum/topic16668.html |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 ![]() ![]() ![]() |
Or this?
![]() Click image to enlarge[/img] |
Jools71 Member Since: 20 Nov 2014 Location: Somewhere south Posts: 3 ![]() ![]() |
hi thanks for your replies its the same one as supacat and i think the hitch height is 22", i still tow with it but the trailer is slightly nose high which i know is not ideal, i think it would involve putting on an adjustable height coupling like the dixon one i just want to make sure that it will be ok as am paranoid that the trailer will come off with horses in it. hope this makes sense and you can answer it
