Home > Maintenance & Modifications > painting grill etc
ksc
England 2014 Defender 90 Puma 2.2 CSW Montalcino Red
painting grill etc
Hi I am new to this site after moving over from the rrs site and was wondering if anyone has painted the grill and head light surrounds on a new deferder.i would like to paint mine gloss black.if you have what paint did you use and was it successfull as I do not want to pay landrover £260 just for the black grill.many thanks
Post #371674 14th Nov 2014 7:35pm
LR90XS2011
Killer has done this as have a couple of others I'm sure they will be along to tell you how it went and what they used DEFENDER 90 TDCI XS,
Post #371676 14th Nov 2014 7:40pm
Venomator
There are a couple of good vids on YouTube for this and I like THIS ONE in particular... Thumbs Up
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #371678 14th Nov 2014 7:53pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
I did mine gloss black.
I rubbed them down with 600 grit,then wire wool.De-greased with thinners,then sprayed with a rattle can.
I use a hot air gun after each coat of paint to stop the paint running.
I did the bumper and spotlight backs aswell.
The finish was prety good.
Post #371684 14th Nov 2014 8:18pm
Velo-felo
United Kingdom 2007 Defender 90 Puma 2.4 SW Keswick Green
Yes I did the same as Sharkey although I did mine in grey to keep it more original (it's older!) but I made sure the paint was for plastics, it copes with the flex better. Also a nice warm day on which to do it makes a big difference. Cavity wax behind them while they are off.
Steve
Post #371695 14th Nov 2014 9:29pm
Rosso_NI
United Kingdom 1993 Defender 110 2.5 n/a Diesel ST Galway Green
Agree with all of the above, done few of them, plastic primer them first gives the paint something to stick to, use a good heat gun between coats, also worth using a coat of clear lacquer, all in rattle cans Thumbs Up
Most decent motor factors will have all this stuff on the shelf.
Post #371705 14th Nov 2014 10:06pm
ksc
Many thanks for your replies I will give it a go when the weather improves a bit
Post #371855 15th Nov 2014 7:42pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Painting Grille
Very straighforward to do, have not done gloss black but have done a couple of sets satin black.
Rubbed down with a scouring pad, degreased and plastic primed then sprayed over with quite a few light coats of satin black.
Looks the part.....
Chris
Post #371878 15th Nov 2014 10:16pm
munch90
Only thing with using a heat gun is the chance of blowing cr@p /dust on to paint , better if poss to use to use a heat lamp
Post #371880 15th Nov 2014 10:22pm
In my experience be very careful of using any heat.
Remember plastics expand and that causes cracks in the paint.
That's the issues I've had in the past, if I did any more painting I'd not be using any heat.
If you do make sure it's about room temp and kept stable.
Post #371881 15th Nov 2014 10:35pm
munch90
Yes agree with above , gentle heat is ok , you want the paint to dry not put a skin on top
Post #371883 15th Nov 2014 10:48pm
About 16- 20 degrees is ideal and somewhere perhaps like a garage.
I've always managed to get good results from spray cans, just as good as a compressor.
Unless you do lots of painting or have a compressor already a rattle can are fine IMO.
The keys are quality prep and patience.
Post #371886 15th Nov 2014 10:53pm
