![]() | Home > Expedition & Overland > Install hannibal family tent on a hannibal rack |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 ![]() ![]() |
captain slow Member Since: 22 Jun 2011 Location: Herts Posts: 356 ![]() ![]() ![]() |
I think if IRC you need to drill through the marine ply base and through the roof rack and then bolt them together. The drilling is easier before the rack goes onto the car. I think i then put the rack on the roof and secured it. Then attached the tent to the rack. It's a bit fiddly. two things - I varnished the ply with marine grade varnish to assist with the weather proofing and used silicone or rubber washers to waterproof the bolt holes. Hope that helps: ![]() Click image to enlarge 2.2 Tdci 110 XS CSW Corris Grey Prince Harry's D3 (gone but not forgotten) 300 Tdi 110 CSW (gone but not forgotten) |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Put the tent on the rack and open up lift up mattress and measure where the rails are on the rack then drill through tent base and rack make sure it is through the centre of the rail on the rack 4 bolts on medium tent and 6 on 2.0 Matt tent easy enough but better done before rack fitted if not possible for rack with clamps on one end and lift up and secure with some blocks underneath so you can get to the bolts make sure bolt mont hit roof when you lower it back down though.
Hope this helps 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
ronwong Member Since: 28 Jun 2012 Location: Singapore Posts: 120 ![]() ![]() |
![]() Click image to enlarge done |
Juddy Member Since: 09 May 2013 Location: Queensland Posts: 63 ![]() ![]() ![]() |
Who's the retailer in Singapore for Hannibal ? 2010 Defender 130 HCPU
1991 110 RFSV PERENTIE www.landybitz.com.au |
RWPrince..
www.4wd.com.sg you can drop them a mail, price looks much cheaper than Aussie or europe sites. |
