![]() | Home > Puma (Tdci) > Puma 2.2 gear change |
Gus Member Since: 10 Nov 2014 Location: Perth Posts: 17 ![]() ![]() ![]() |
Exactly the 90 is 1/4 ton lighter than the 110 and my SWB feels like it would pull quite happily at 1500+ rpm but it seems the rev hang feature is set up to assist in swapping cogs once the road speed equates to 2000 rpm in the next gear up.
Quick update,
I think I finally have it sussed. To avoid the dreaded rev-hang related transmission clunk thing it's less about what revs you're doing when you change down, it's actually more important to be at the correct road speed so that the next gear comes in at ~2,000 rpm: In gears 1st to 3rd you need to change down at roughly ~3,000 rpm to 'comply' with the rev hang feature and ensure that the next gear comes in at ~ 2,000 rpm. However, 4th to 5th is different as I've found changing down once the revs hit ~2,500 in 4th equates to 5th coming in at the pre-requisite ~2,000 rpm. I can only assume that the jump in gear ratios between 4th - 5th is shorter than the lower gears. The jump in gear ratios between 5th and 6th must be bigger again because you need to be back up at ~3,000 rpm in 5th for 6th to come in at 2,000 rpm. I've found that if I'm working against the ![]() Basically the rev-hang thing is pish as it effectively forces you to drive in a particular style which is going to be alien to most Defender/Series enthusiasts. My guess is the feature is there to protect the drive train from unnecessary strain but if you fight it then ultimately it's going to cause the same damage it's there to prevent. At least now I have a work-around I am once again at peace with my transmission, so hopefully this will be of use to other equally baffled first time 2.2 Puma owners. No apologies to those who think I'm teaching them to suck eggs, would you like some chilli mayo to go with that? ![]() |
Vmesch Member Since: 06 Dec 2014 Location: Antwerp - Lier Posts: 47 ![]() ![]() |
I also had some issues changing gears at the beginning but found out that for a standard road drive -no hurry or aggressive driving- the Def 90 2013 version shifts quite smoothly when keeping the revs between 1500 and 2200 rpm.
I've written down the speed at 1500 revs for the different gears and put these in chart. 2nd. 20 kph (12.5 mph) 3rd. 30kph (18.6 mph) 4th. 42kph (26 mph) 5th. 55kph (34 mph) 6th. 72kph (44.7 mph) Pushing the revs up to approx. 2100 rpm and shifting up while letting the revs drop to 1500 rpm by releasing the gas pedal, will gently bring me to the next gear - straight on the revs/speed line of that gear! No clonk to be heard... Theoreticaly, this should be the same if you rev up to 3000 and let the revs fall down to approx. 2000 revs when gearing up. But I haven't tried this yet... So not sure if the revs fall down the at the same speed. But this could be compensated with a faster or slower gear change. I'll try this later on. Only question: what about the consumption??? Hard to say as the Def has no instant consumption reading.... ![]() Click image to enlarge |
AintreeCSW15 Member Since: 08 May 2015 Location: Northern Ireland Posts: 2 ![]() ![]() ![]() |
Hi everybody,
I'm another Defender 2.2 owner with occasional frustrations of kangarooing .. But I think it's my right foot that's why I'm asking nicely how any body has adjusted the throttle to take the free play out of the first 5-10mm of pedal travel. I think my problem at slow speed is my right foot doesn't always apply enough to ensure a smooth change ![]() Any help is much appreciated Thanks |
Hi everybody,
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Are you moving from 4th to 6th pickles..............37.5 mph in 6th ..........mine struggles with 4th at anything below 30mph so changing to 6th at such a low speed feels wrong!Is the air thinner in aus and also i thought defender owners disliked this new fangled kph system over mph ![]() |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
The first part of the throttle torque request maps does not give as much power as the higher end does,, each gear is also differently scale
giving to much to soon can give a feeling like a grayhound on/off and so in some case makes the drivability worse, from my experience each driver and each car are slightly different and resetting adaptive valies for the engine with diagnostic tools can sometimes help. regards Pete |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 ![]() ![]() ![]() |
We're DEFINITELY ok in 4th below 30MPH (60kph). I feel that the secret is to use a light throttle. Like I said, Gracie's fine at 30MPH (60Ks)in 6th, & if you want to increase speed, then just a light throttle & away she goes,...in traffic it's a little different,...5th gives a bit more "flexibility". One thing I haven't mastered is avoiding "backlash/clunking" from the driveline when changing up in gears. Tried different methods in different gears, sometimes I think I've got it right, & the the next time I haven't,...can't seem to match the engine RPM with the gear that I'm changing into,....if that makes any sense. Pickles. |
I am worried i have a purchased a duffa pickles..............just to be precise 60kph is 37,5 mph and mine would be just about ok if you were dropping down speed to 60kph but i would never change to 6th at that speed if i was going up the gears.
at 30 mph or 48kph mine will run in 4th but feels like you should be in 3rd.............as i say it does feel like your driving with the brakes on and it does take some getting used to! |
