Home > Td5 > Occasional Non-starting Issue
Page 2 of 2 <12
Kent_keith
England 2005 Defender 90 Td5 CSW Zambezi Silver
Did you ever get this resolved, it's no happening to me I just can't stand mysteries Very Happy 2005 TD5 90 CSW XS
Post #383630 31st Dec 2014 2:21pm
Stuadh
Scotland 2001 Defender 110 Td5 HT Fuji White
I'm not sure. It did it once, a few days after I earthed the unit, but never since. If it happens in the next few days, I'm blaming you for mentioning it. Wink
Post #384643 3rd Jan 2015 9:20pm
Kent_keith
Sounds fair Thumbs Up 2005 TD5 90 CSW XS
Post #384646 3rd Jan 2015 9:27pm
NickMc
Like I said bad wiring into the underseat compartment Whistle easy thing to do is give it a wiggle under there next time it doesn't start, hard fix is to book it into a good auto electrician Thumbs Up
Post #397762 10th Feb 2015 8:56pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I have had the same problem. With me it was a bad connection at the as10.
But I had more problems with bad connections as mine had swimming lessons in deep brown water?:
 Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #397832 11th Feb 2015 9:38am
NickMc
Yep the 10AS wires go up over the gearbox and run in a ribbed conduit with nothing covering the wires really seeing this a lot on them now. The header blocks giving problems too.
Post #398026 11th Feb 2015 10:09pm
darryloh
United Kingdom 2000 Defender 90 Td5 HT Coniston Green
Nickmc what is a header block exactly? I've seen this referred to on Haynes manual, but what does it look like?, and where exactly are they located? it's just I have a td5 which has suspected earth issues Very Happy
Post #398064 12th Feb 2015 7:28am
NickMc
A header block is basically I guess a junction box for wires like earths. Eg the White one on the bulkhead beside the brake Servo or the one beside the ECU under the drivers seat. They look like plastic moulded rectangles.
Post #398347 13th Feb 2015 12:48am
Page 2 of 2 <12
