![]() | Home > Td5 > Clutch pedal gone soft, trouble selecting gear |
Could be the seals in the master or slave cylinder letting the fluid past so you don't get compression or the clutch could be toast.
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2957 ![]() ![]() |
The slave cylinder pushrod has been known to pierce the release arm
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
I would replace the clutch fluid as it absorbs moisture and that moisture could boil and create an air lock so that when you depress the pedal you compress the air instead of the fluid, that would explain why the problem lessened when the car had cooled.
It is a good idea to replace the clutch fluid very two years as you do with brake fluid 2005 Td5 90 XS Steve |
I thought that was on tdi's and td5's have cast release arms? |
tpy Member Since: 27 Jan 2014 Location: paris Posts: 17 ![]() ![]() ![]() |
Now that makes a lot of sense, thanks! I'll go ahead and purge the hydraulic fluid and let you know if problem is solved. Cheers. |
Hello Forumites, here is an update of my clutch situation:
I had the master and slave cylinders changed, the clutch pedal adjusted to give a longer course to the master cylinder rod. It seems to be ok now, I drove 600km this weekend (to the coast of Normandy and back, I could almost see you guys!), symptoma have disappeared, clutch pedal firm as it should be and no trouble selecting gears. Could be short lived, but I'd love to understand a bit more of what the cause of the problem is if it is related to the clutch mechanism, before going for a complete clutch change. From what I understand from the TD5 2005 clutch design, I dont see how a worn clutch disk or flywheel could give that sort of trouble. Could it be the pressure plate? Are these parts known to wear out? |
Thanks mk1collector, that's why I had these cylinders changed, so if it was only that I should be fine. However no fluid could be seen anywhere along the whole hydraulic circuit and the reservoir at the top was pretty much full, so if there was a leak it must have been a really small one.
Some people I spoke to about this clutch problem told me the clutch mechanism could be bust, but I dont see which part of it if not the command should fail to give such effects (soft pedale, no gear selection possible). |
I meant the internal seals so there wouldn't be any leak. Basically when you press the pedal the fluid isn't pushed because the seals let it past.
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 ![]() ![]() ![]() |
Good Morning tpy, I have just been reading your previous post's and was wondering by having your master and slave cylinders replaced did this resolve the problem of your clutch pedal going soft? At the moment I'm currently experiencing exactly the same symptoms as you had, and I have had the master cylinder replaced, and also due to the fact the fluid was jet black this was replaced also, though now think I should have had the slave cylinder replaced at the same time, I drive a 2.4 Tdci, though I suspect the clutch hydraulic systems are not dissimilar to the TD5? Cheers Keith |
gearbox out job to do a slave cyl on a puma 2.2 or 2.4 (called a concentric bearing , bearing and slave are one unit ), its inside the bell housing unlike a td5 which is outside
Hello schuee, Replacing the master and slave cylinders did resolve my problem indeed. I drove some 2000km (very little off-roading though, unfortunately) since and have not seen the symptoms coming back so far. Sorry to read above that changing the slave cylinder is probably less simple of a job on a Puma than on a TD5, but at least my experience tends to confirm Mk1collector's explanation given earlier in this thread and to show these symptoms dont necessarily mean the clutch should be replaced. Good luck! |
Hi tpy,
That's good news then, hopefully by replacing the slave cylinder this will also resolve my problems, from what I can gather it's requires the gear box to be dropped to be replaced? Thank you for your reply ![]() Cheers Keith |
Hi tpy,
Slave cylinder replaced and all is working as it should do (for the time being) ![]() Cheers |
