Home > Puma (Tdci) > ABS/TCS warning lights |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Dont count your chickens yet,lol. FYI, £1400 inc vat from Br*tpart. Generic code readers aint very helpful on Defenders, Snap on Solus,etc,Either LR's own Testbook, Autologic or diy, Hawkeye,Nanocom or Lynx, I have Lynx. Pov.spec,ftw. 2006, 110,TD5.
31st Oct 2014 10:35am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
A bit more info ref Bulletin LTB00078v2 regarding warning lamps. 2.4 90 XS
24th Nov 2014 4:48pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
Hi, can you guide me to the fuse please?
Thanks. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. |
24th Nov 2014 8:23pm |
Good Morning RD,
Look under the drivers seat remove the secondary fuse bix lid, there are a line of heavy duty fuses, check through the clear cover on each fuse to see if one has blown. 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
25th Nov 2014 9:11am |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2114 |
there are other things that can cause this fault as well -I had the same problem with mine a while ago and it turned out to be an earth problem on the ECU - so had that re-earthed and all was fine at a cost of £20 ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
25th Nov 2014 4:11pm |
