Home > Maintenance & Modifications > Guidance with Bulkhead removal bar installation
FLFAMILY
United Kingdom 1985 Defender 90 BMW M52 2.8i Petrol ST Keswick Green
Hi - Prior to leaving the UK I had picked up a LR original bulkhead removal bar pictured below from CSK. I am now trying to get it installed, and have been told I am missing the plates that go at the bottom of the bar. I was in touch with the local LR dealer (Listers)close to our residence in Worcestershire, but did not have any luck with them, After getting back to the US I tried Foley’s, and they have sent me the bolts M10 for the main bar and M8 for the other brackets, but they did not have the plates.
Can someone please advise if these plates can be sourced from the UK? If not, will someone be kind enough to show me the picture and shoot across the measurement of the plate. I will look into having them made here by a shop. Additionally, if there are instructions for the installation of the bar as a whole I would also appreciate getting those.
From what I can see the part# from Land Rover for the bulkhead bar is AH12-613A56-AA CKCPA
Thanks in advance for your help and guidance.
Post #367099 25th Oct 2014 4:24pm
FLFAMILY
Pictures are in my gallery, not sure how to embed them in the message Smile.
Post #367100 25th Oct 2014 4:25pm
Venomator
/\ /\ If you open the iMage in your Gallery you will see an option, underneath it, to add to your posting list, this will place a thumbnail under your text input box and if you click/tap on this it will insert it to your post... Thumbs Up  Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #367101 25th Oct 2014 4:34pm
FLFAMILY
Thank you
Post #367104 25th Oct 2014 4:38pm
Killer90
Site Sponsor
You can use nut and bolt instead of using the plates Thumbs Up have just cut and fitted one today chap
Thumbs Up Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #367119 25th Oct 2014 5:25pm
FLFAMILY
Many thanks Chris and thank you for all your help with all the parts.
Post #368050 29th Oct 2014 5:18pm
CatherineF
A question on this rather than starting a new thread.
How easy is it to remove the bulkhead?
What advantages/disadvantages does it have?
Post #382595 28th Dec 2014 11:09am
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
I have removed mine,myself.
Not too difficult,if you are OK with a grinder.
You need to strip out the seats & carpets,cover all remaining glass,to protect it from sparks.Take the rear side panels off,(2 people needed to lift them off.)
You dont need to remove the roof,I just jacked it up from the rear.
Then just cut out the bulkhead,and grind back,paint the raw edge,et voila. Thumbs Up
Post #382604 28th Dec 2014 11:54am
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
I've done this on mine too, pretty easy for anyone who's handy with a grinder, you'll have to be handy with a hoover for the mess at the end too! Click the link in my signature, there's a paragraph or two in there from when I did it. Tom
@tditomprice
100ā€¯ Defender Hybrid
2010 Alaska White 90 HT
Post #382617 28th Dec 2014 12:50pm
CatherineF
Hhhhhmmmm, might leave that mod and get the bulkhead re-painted instead.
Post #382618 28th Dec 2014 12:52pm
