Home > Wheels & Tyres > Recommended Tyre Size
Grenadier
Hello all,
Just invested in a full set of Blindos, direct from AR Casting in Italy. (Called the F15 Tech). Stellar service from Elena, BTW. Probably not much use in the UK, but great value for delivery here in the Alps in €s.
Looking to shoe them with Cooper ST Maxxs, but AR Casting will not supply dimensions for the tyre and very hard to get an answer in France as they do not know Blindo.
Any recommendations anyone? Nothing oversized, just traditional.
235/85R 16?
265/75R 16?
Thoughts?
Thanks as always. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #364538 14th Oct 2014 10:22pm
Cat81
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Orkney Grey
I also have Blindo wheels on my Defender and have put 265/75 ST Maxx's on them. They fill the arch nicely without looking out of proportion. I believe the 235/85's I had before did not work on the 110 and were too narrow for the body size. But that's all esthetics in the end!
A friend of mine has BFG KM 255/85 on his 110 and that is the other size I would consider; they give additional clearance for off-roading.
Marc
Post #364627 15th Oct 2014 11:48am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I started out with 235's on the old TD5, but went for 265's when I needed (wanted) new tyres.
Only problem(s) I had were, the 265's reduced turning circle, so I got some wheel spacers. Then the problem was that off-road the mud and s**t went everywhere, up the sides, on the roof, etc.
So on the new truck I have standard 235's and will stick with this size.
I know the 265's with spacers "looked" good - but that was all - no difference in ride, handling, off-road grip, etc.
Post #364636 15th Oct 2014 12:07pm
Grenadier
Thank you Cat81 and DNH. Bow down
I was thinking 265s, and given what Cat says about ST Maxx's specifically, I think that'll be my choice. Without wishing to sound vain (ok it will) I think the larger size will look better against a 110, especially with mine being white and with the mods added to it. I like the slightly squatter stance the 265 creates. I can forsake the extra mud and the fact that the turning circle will have gone from a Royal Navy frigate class to that of a US Navy carrier class....
Cheers for the numbers.... Thumbs Up Monsieur Le Grenadier
Post #364642 15th Oct 2014 12:27pm
285/75 x 16 is another popular choice which would work well on Blindos.
Same caveat about dirt - my Defender used to get plastered (and you had to remember to shut the windows off-road) until I fitted Mudstuff Dirt D-Fenders, a reasonably proced and very simple solution.
The turning circle of my 110, after careful adjustment of lock-stops, is significantly better than that of my Disco 2.
Post #364647 15th Oct 2014 12:49pm
Grenadier
That's a big wheel. Do you have a photo? Monsieur Le Grenadier
Post #364652 15th Oct 2014 1:04pm
Grenadier
Just looked on line. 285/75 is a monster tyre Shocked . Probably great off road, but I have to keep a semblance of normality as I will be ferrying clients about! Maybe when I tackle an exped of some sort in the future... : Question Monsieur Le Grenadier
Post #364655 15th Oct 2014 1:13pm
Grenadier
Marc
Marc,
Will I need an offset for the 265/75 option?
It is an as Standard 110 SW (11/2011), currently with OE steel white wheels.
Ta Monsieur Le Grenadier
Post #364657 15th Oct 2014 1:26pm
Here you go. Old photo when running 285/75 Kuhmos (I now run KM2s). Boost alloys with 30mm spacers.
Post #364663 15th Oct 2014 1:55pm
Grenadier
Many thanks. Yes look great, a meaty tyre, but best suited for more frequent off-road adventures. Do you know if I need an offset for my Blindo-265/75 configuration? Monsieur Le Grenadier
Post #364665 15th Oct 2014 2:07pm
Cat81
From memory the Blindo has a 15 offset (you will be wider 17mm per side compared to boost alloy) so you can actually work on the stoppers to decrease turning radius; it will make a notable (and improved) difference.
No problem with fouling the side of the car too much; the Blindo + 265 ST Maxx combination just comes flush with the arches. I can try and post pictures (but later, as I have no access in the office ...)
Post #364677 15th Oct 2014 3:29pm
Grenadier
Many thanks Monsieur Le Grenadier
Post #364683 15th Oct 2014 4:04pm
Cat81
Grenadier - I am sorry I have not been able to post anything (I leave in the morning with the night, and come back with the night ....).
I will take the pics tomorrow and have them on the thread after that!
M
Post #365153 17th Oct 2014 8:46am
Grenadier
No worries, the order has been placed. Cooper ST Maxx 265/75s on Black Blindos mounted on Fuji White 2011 SW. Should be smart.
Many thanks to all of you.... Monsieur Le Grenadier
Post #365160 17th Oct 2014 9:28am
Cat81
Congrats! You won't regret it - this has been the best spent for me so far...
M
Post #365230 17th Oct 2014 2:58pm
