![]() | Home > Tdi > 300tdi rattle bearing under load. Advice needed |
Timo Member Since: 14 Jul 2011 Location: Peterborough Ontario Posts: 171 ![]() ![]() ![]() |
So i have everything just about buttoned up for my V8 to 300tdi swap on my 110 (including fixing the footwell). When I finally got the muffler installed I had what I thought was a rattle/bearing noise when the turbo kicks in under load. I changed the Turbo out for another unit as I thought it was out of balance or had a bearing issue.
The turbo swap (with exhaust manifold) was really straight forward and only took about 2hrs. Unfortunately my noise is still there. It idles perfectly, maybe a bit low. Sounds great until I really step on it then it gets this really bad rattle/ bearing noise. If i back off on the throttle it completely goes away. Anyone have any suggestions of what I should do to troubleshoot? Thanks Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 ![]() ![]() ![]() |
Not wishing to be patronising when I say this but it's not exhaust system touching the under carriage? Or a heat shield vibration? Rhubarb and custard let fly with their secret weapon.
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
im with lambert! i recently changed tail pipe and mid pipe on my tdi. a few weeks later a new noise developed. sounded like a dry gearbox bearing or something similar. turned out to be exhaust pipe vibrating in rubber mount!!!
![]() my youtube channel |
Lambert, no worry about patronizing, i asked!. The more i think about this I wonder. It only started after I had the muffler done.....let me check
I was so convinced it was the Turbo Cheers Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
So after checking over a few things with some suggestions from a friend. ........
Turns out the lower clamp on the intercooler had completely come loose. It was rattling around under boost pressue/load and I was also losing a considerable amount of power aas the hose was not properly conmected. Best it has driven since I did the engine swap!, Thanks for the input Cheers Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
good news
