Home > Puma (Tdci) > Check your nipples
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Check your nipples
Ive even got one missing.
Just gone to do an intermediate 6k service (at 18k), oil grease prop shafts etc. I have found that one of the front UJ propshaft grease nipplies is missing completly and all the others are extremely loose. This cannot be just my vehicle (hope it is for everyone elses sake) as it was all the grease nipples. I'm guessing LR dont check the props when they are fitted during production as they probably just arrive complete from a supplier. Sad
Cheers Rich
Post #2110 13th May 2008 8:50pm
Tony_Hillerby
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Santorini Black
Same as mine, went to grease up the propshafts at 3k and found the front prop UJ adjacent the transfer box had the grease nipple missing.
Checked the others and they were loose as well.
It got replaced when the fuel pump died the week after and had to be recovered to the dealers
Tony
Post #2149 20th May 2008 8:45pm
dshickle
2007 Defender 110 Puma 2.4 CSW Galway Green
where are the grease nipples. Have had a quick look and can;t spot them.
And is there any specific grease type that needed.
Any help greatly appreciated.
David Disovery 3 TDV6 SE
Defender 90 XS 2.4
Defender 110 S D250 (MY22)
Post #2158 21st May 2008 10:03pm
Tony_Hillerby
The grease nipples are in the centre cross of the UJ, not like my other 90s wher they are in the side of the UJ and easily seen. I could only detect the hole by feel and even knowing where it is its difficult to see. The grease nipples are cranked at 45 degrees and difficult to get a grease gun onto. They may need rotating slightly.
Tony
Post #2165 24th May 2008 7:57pm
mse
Dont joke my 90 is missing the passenger side dash inspection panel - i dont want to look to see if anything else is missing Big Cry Mike
Post #2171 25th May 2008 9:40pm
I re-checked my MY2010 defender 110 and the front prop still only has 2 nipples, at either end, should I have a middle nipple ? can the be a sorted out on the warranty ?
Post #63635 14th Mar 2011 8:11am
Grockle
the dealer will fit new props to any Def that has missing nipples, it was a manufacturing fault they weren't tightened up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #63639 14th Mar 2011 8:30am
cheers grockle
Post #63654 14th Mar 2011 9:37am
Grockle
Thumbs Up 2.4 90 XS
Post #63655 14th Mar 2011 9:38am
MK
Off road vehicle without nipples? Cheap solution IMHO Puma 110" SW
Post #63660 14th Mar 2011 10:36am
