Home > My Defender > My first 90 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20453 |
I keep my aerial constantly down, then again I don't use the radio.....
Far to prone to getting snapped off! Especially around here. |
28th Sep 2014 3:16pm |
CLCraig Member Since: 05 Aug 2014 Location: Somerset Posts: 104 |
That's what I was thinking to be honest. Seems to be a bug magnet with the upright windscreen lol
28th Sep 2014 3:24pm |
Weekend away or candlelit dinner for two perhaps?
Doesn't really matter as my top portion wore out and at full extent it used to go down on it's own. If you've got good reception with it down you've no requirement to extend and tempt some toe rag to bend or snap it. Great looking truck. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Sep 2014 3:41pm |
Haha dinner for two sounds lovely thank you big change from my previous car.
28th Sep 2014 4:00pm |
Or three if you include the Defender.
28th Sep 2014 4:28pm |
Dont want to offend him
28th Sep 2014 6:24pm |
So King Kong experienced his first spout of rain today and all appears dry so however when looking around the seat base I noticed a white foam looking pad between the seat base and trim beneath the door line. This pad seems out of alignment on the drivers side compared to the passenger could someone tell me if this is a defender trait or is it likely to be a problem many thanks in advance Craig.
Drivers side Click image to enlarge Passengers side Click image to enlarge |
4th Oct 2014 1:46pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
hi craig mine is the same! i think its coming from the lower door seal front edge of door...gave it a squeeze and water came gushing out......i have no idea how to fix it but sprayed the door innards with bilt juice.....rust magnet me thinks!
5th Nov 2014 9:50pm |
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 |
If you are referring to the foam 'packing' strip - it's only there to fill the gap and from what I've seen seems to be a sort of double sided sticky tape with a foam filling. Probably costs JLR about £1.00 for 1000 metres and appears to fall out/sag out of some joins almost as soon as it is inserted at the factory.
You might like to get a windscreen scraper out (now that frosty mornings are upon us) and reposition it - if it offends thy eye? |
5th Nov 2014 11:15pm |
