Home > In Car Electronics > Spot wiring |
Sort of, wire the spots through a relay which is triggered by a feed from the high beam circuit. Have a search on this forum, there's the search button on the header at the top or just use google.
6th Sep 2014 9:34pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20546 |
It will blow the fuse, up the switch and possibly melt the wiring.
Needs to be independently fused and relayed with a trigger tap taken from the main beam. In other words no extra load on the Defender harness. |
6th Sep 2014 9:52pm |
Here is a diagram:
The override switch is optional and only further complicates the wiring. You would however need a switch for roof lights to be legal. |
6th Sep 2014 10:06pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 671 |
I used a bolt on bits kit to fit my spots - wasn't worth making my own for this price: http://www.ebay.co.uk/itm/Bar-Spot-light-l...35c1c891ff
11th Sep 2014 10:16am |
Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245 |
Mmm nice one thanks.....is this suitable for an electronic numpty (me).
11th Sep 2014 6:09pm |
