![]() | Home > Td5 > Boost Gauge Installation |
silky16v Member Since: 11 Aug 2014 Location: Cumbria Posts: 99 ![]() ![]() ![]() |
You should ideally tap the inlet manifold as you want the boost pressure after it's passed through the intercooler
I think the boost pressure is available via the engine diagnostics so for example an obd reader could read it from the ecu
Stue5 Member Since: 06 Jul 2014 Location: Marche Posts: 111 ![]() ![]() ![]() |
I don't think the td5 defenders were Obd2 protocol compliant as being a duel purpose vehicle.(need nano com or some other special gizmo). But the pumas are. If running a boost box it would give a false reading. I have mine in the top of the inlet manifold at where the egr used to enter.
Sorry if I got this wrong , please correct me! ![]() ![]() ![]() ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
Have you checked Boost gauge reading with a reading from the ECU via a Nanocom etc? 1999 Defender TD5 110
I tried with a generic eBay obd2 reader, which sort of worked on the p38 and quite well on other cars, but it did not talk to the 2005 td5. Then I read some where (cannot remember) about the defenders not needing to comply.
Nano com wise I have never played with one. Range Rover p38 4.6 99 lpg(gone ![]() ![]() |
generic code readers won't work
so either fit a EGR delete and drill tap this for 1/8pt nipple take off or remove inlet manifold (clean it while its off) and do the same you can then fit any generic boost gauge |
I have seen the EGR blank kits with the boost gauge pipe welded on already, i would have gone for one of those had i seen one earlier.
You jogged my memory silky16v ![]() After a bit of hunting, http://www.egrvalve.co.uk/index.php?page=l...d5-egr-kit Range Rover p38 4.6 99 lpg(gone ![]() ![]() |
^^^ That is exactly waht I have fitted to my TD5, made by Allard Engineering.
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
