Home > Technical > Transfer box question
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Hi guys
Can anyone tell me what years they changed the transfer boxes on the defender L77 as i think mine being an 1988 model mite have the old 1:1.6 transfer box in it and want to change to a later 1:1.4 but not sure what years they changer Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #351057 11th Aug 2014 6:10pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
im pretty sure only some 110s and 130s had the 1.6 box ?
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #351140 11th Aug 2014 11:33pm
cornish rattler
Just googled land rover 90 transfer box's and it came up with the differences of transfer box's used from early 90/110's to late td5's and it looks like all early 4 cyl none TDI used the 1:1.6 transfer box which answer's my question so not entirely sure wether to go for a 1:1.4 or a 1:1.2 discovery transfer box Confused Graham
Post #351179 12th Aug 2014 8:16am
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Graham you can tell from the serial number which ratio you have...check out ashcroft site for number location and specs.
http://www.ashcroft-transmissions.co.uk/in...oductId=45
As for which ratio to run...will pend on tyre size too... a tdi is likely to struggle with 1.2 disco box and say 285 tyres.
N.
Post #351191 12th Aug 2014 9:38am
cornish rattler
Ok cheer's nidge but would it be ok with 265 tyres which i have Smile Graham
Post #351342 13th Aug 2014 7:33am
landy andy
You will know if you have a 1.6 box as at 60 mph it's screaming. Not a standard fit for yours. 265 and a 1.2 box depends on a few things. If you tow don't do it, if you have played or are willing to play with pump, and possibly bigger intercooler it will be ok. Got to question miles you drive, quality of existing box, cost of replacement box. It won't save you any money fuel economy wise.
Andy
Post #351344 13th Aug 2014 7:40am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
If the box is in good shape I would go for bigger tires. Mr. Green Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #351348 13th Aug 2014 7:58am
Nidge
As Andy says, 265s with bigger intercooler and pump tweak, will sit nicely at motorway speeds....
Maybe nicely is the wrong word, as it is a 200tdi after all.. Rolling with laughter
N.
Post #351349 13th Aug 2014 8:01am
Lou Sparts
There should be a sticker on your transfer box with the ratio on it, it's my understanding that the 1.4/1 transfer box was used from the Turbo Diesel onwards, 1.6/1 was used on normally aspirated defenders prior to that. 2005 Td5 90 XS
Steve
Post #351443 13th Aug 2014 6:29pm
shaggydog
I think the word you are looking for is Agreeably.
I have a standard 1:4 box and 265/75/16 and I usually cruise quite happily between 50 and 60 on motorways.
I anything over 60 and the noise and MPG is awful, at the moment I'm returning around 33-34MPG.
Cornish, if you look on the back of your T'box next to the handbrake drum there should be a sticker which will show if you have a 1:6 or 1:4 ratio box.
Personally, with your tyres I wouldn't want to go faster than 50mph anyway due to the noise and the grip on road.
Remember, its not how fast you can go, its how fast you can stop!
Post #351456 13th Aug 2014 7:02pm
shaggydog
Looks like this Thumbs Up
Post #351457 13th Aug 2014 7:10pm
cornish rattler
Right ok shaggy looking at your pic i can defo say i don't have that sticker on mine so if the weather is ok tomorrow i may go and have a look at the serial number on the transfer box and see if i can work out which one i have Smile Graham
Post #351508 13th Aug 2014 10:47pm
cornish rattler
Right i have had a look under the landy for the serial number but couldn't find it so i will have another look on Saturday when i have more time Sad Graham
Post #351545 14th Aug 2014 9:52am
cornish rattler
Ok just googled it and found the s/n is right next to where the sticker should be so i was looking in the right place but after cleaning it down where the s/n should be stamped is just blank but as i say will have a better look on Saturday Sad Graham
Post #351549 14th Aug 2014 10:00am
Martin
Site Admin
You can see the end of the serial number in that photo above, just to right of bottom left, it ends 14D on that box.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #351550 14th Aug 2014 10:10am
