Home > In Car Electronics > TD5 Immobiliser
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
TD5 Immobiliser
Hi folks,
Is this a known problem with a known fix?
Recently my truck has started to become tricky to start.
Key in ignition, orange engine light comes on, and the glow plugs come on and go out.
Then red immobiliser light then flashes on, and car won't start.
I tried unsettling the alarm, still not solved, tried about four or five times, eventually she did clear and fire up.
Any ideas what could be doing this?
Andy[/list]
Post #350873 10th Aug 2014 8:01pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
There's many possibilities, perhaps the battery in the keyfob?
Post #350878 10th Aug 2014 8:14pm
ROBBONTHEROCK
Yeah, I was wondering about that.
The thing is on each occasion it hasn't had the alarm armed / deactivated.
It's a strange one!!
Andy
Post #350885 10th Aug 2014 8:36pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
As mentioned, a new battery in the key fob is not a bad starting point. Normally, when the battery is low, there is a tell tale flash of some sort from the indicators when you arm the alarm (can't recall what it is but it's noticeably different)
Also, I assume the plipper is still in close proximity to the ignition barrel for the immobiliser to detect its signal (as in, you've not recent taken the plipper off the ignition key ring and shoved it in your pocket for example). Jon - 110 td5 [sold]. Currently Defenderless.
Post #350890 10th Aug 2014 8:57pm
