Home > Wheels & Tyres > Tyre pressure?
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Tyre pressure?
Hi all...
I've got a question about tyre pressure. When I picked up my 110 from the dealer, they recommended a different tyre pressure as opposed to the manual, for the stock tyres - 28 on the front and 34 on the rear. These figures were also documented on some sort of alignment sheet they gave me.
Does anyone else run these pressures? The tyres are stock Grabbers.
When I picked it up the other day however from the dealer after the 12k mile service, they were on 30+ on the front and 40 on the rear. I only checked because it seemed to me that the 110 was drifting a bit to the left, and I wanted to be sure that the pressure was ok.
Post #30067 18th Apr 2010 7:13pm
CFB
With all the different tyre sizes people fit to Defenders, the pressure is always hard to benchmark. I run my 265/75/16's at 32 front and 38 rear and it seems to work well for me. There was no reference for this, i just tried it and it seems right. Andy
Post #30084 19th Apr 2010 7:32am
K9F
On standard Grabbers on Boost Wheels these pressures are printed in the Owners Manual. Worked for me too!
Dog Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #30087 19th Apr 2010 9:40am
CFB
That was a lucky guess then Laughing Andy
Post #30088 19th Apr 2010 9:55am
harveyg77
I have the 235/85r18 Grabber TRs on Boost alloys fitted to a 110 utilitywagon.
The manual states 30PSi front and 48PSi rear. This seemed ok for the front but hugely over ambitious for the rear. the fronts are softish looking, i.e. the sidewall bulges a little on contact with the ground, whilst the rears don;t seem to at all. Logic would dictate that maybe the fronts need more pressure, whilst the rears are over inflated.
Are you guys saying that 32PSi front and 35-40PSi rear is a better combination?
Thanks,
harvey
Post #30095 19th Apr 2010 11:38am
CFB
48 for the rears seems way too much unless fully laden or towing heavily, mine has a box of off-road kit in the back (not that heavy) and occasionally 2 passengers and 38 seems fine Andy
Post #30097 19th Apr 2010 11:51am
K9F
harveyg77 wrote:
The manual states 30PSi front and 48PSi rear.harvey
You sure you haven't got your threes and fours mixed up? Haven't got it to hand but my manual states 30 front 38 rear! Ran those pressures for 16 months prior to wheel/tyre replacement combo no problems at all. If what you are stating is correct it is a misprint, get LR to provide you with a new set of rear boots, 'pound to a pinch' if you've been running with those pressures for any length of time you got wear issues????? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #30099 19th Apr 2010 12:05pm
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Yeah, manual states 30/48. Did experiment a few times and settled on 28/38 with generally driver only and no load in the rear. Seems to work fine with no uneven wear or handling issues.
On a related topic all tyre manufacturers recommend checking tyres when "cold". Often wondered what this actually means because ambient temperature could be from below 0deg C to 10deg in the winter whereas it could be from 10deg C to 25deg C in the summer!
Post #30110 19th Apr 2010 1:36pm
Eduardo
I use 30 in the rear and 40 in the back without load.
With 48 the truck gets quite bumpy.
Cheers Eduardo
Post #30112 19th Apr 2010 1:53pm
heinrichnel
Namibia 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I have 235/85 Goodrigde AT and are running 200kPa in the front and 230kPa in the back, no problem. Much softer ride too!
Post #30116 19th Apr 2010 2:49pm
harveyg77
Mine is a 110, the manual states 30PSi front for normal conditions/towing/max gross load. 48PSi rear normal conditions and 65PSi rear for towing/max gross.
Ride is quite hard/choppy, so maybe dropping the rears to 38PSi might be beneficial. The manual does state 30 front and 38 rear for the 90.
Harvey
Post #30128 19th Apr 2010 4:46pm
mse
Out of the book:
Tyres
Front: 30psi (2.1 bar)
Rear: 38psi (2.6 bar)
Wheel Nut Torque: 133Nm (98lb-ft) Mike
Post #30181 19th Apr 2010 10:33pm
MK
F&R:32psi for the city (yes, we have paved roads)
Long distances: F: 34ish, R:38ish (4 people+250 kg) Puma 110" SW
Post #30184 19th Apr 2010 11:43pm
austen
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
I wonder why LR specify such a low pressure for the front? I run 38/42, but the dealer always adjust to 42PSI all round!
Austen. Rover 12 1935
Rover 20 1940
Rover 100 1960
Defender TDC1 2008
FL2 TD4 2008
Post #30189 20th Apr 2010 6:19am
K9F
austen wrote:
I wonder why LR specify such a low pressure for the front? Austen.
I always thought it was to take into account shift in weight and moment in certain conditions of the vehicle (for example heavy braking). Also the fact you have the weight of the engine at the front???? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #30194 20th Apr 2010 7:31am
