![]() | Home > Expedition & Overland > Oztent Foxwing - any reviews ? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
Went up to nene overland Friday for a look at/buy the hannibal awnings. It's more saggy than a very saggy thing, and I don't understand how it will work in rain. Not sure if I'm missing somthing, but nene could not help with explanation, and mentioned that they doubt that it had enough strength to deal with side panels being fitted.
Andy |
Tom Mc Member Since: 07 Jan 2011 Location: Bedworth, Warwickshire Posts: 63 ![]() ![]() |
Blimey, and that's a Hannibal, which again because of the name you would expect to top drawer. Can't be cheap either?
You see, all these awnings worry me. Wind can be a real killer, so if for instance the legs are not up to the job, then the best heavy duty stitching in the world won't matter a jot if the darn thing collapses. Alternatively, if the fabric or construction is suspect, that can fall apart and you're left with nothing but the frame. More research needed methinks! |
I was amazed, went up there to buy rack and awning. Then saw a 90 with awning fitted, it had a large puddle in each fabric section between then arms. Typical hannibal quality metal work, and welding, great ripstop fabric with spot on stitching, but however tight you pulled it, you could not get rid of the puddles. Very very nice hinge section, but no weak link, if a gust of wind does damage, which could then cause major damage. Then was more shocked when informed not strong enough for sides, and that's what I require.
Andy |
But then look at the sales picture
![]() Shows the problem |
There are many reasons why companies have different prices for what may be exactly the same or what appears to be similiar products.
One reason is VAT. If a company is not VAT registered they basically have a 20% advantage straight away
Really? From Tuff Trek website
I for one would like to know of a UK manufacturer of well know brands of roof tents! In our travels we have seen many designs of vehicle awnings and of varying quality. Some of them could be best described as superb H2O collection systems, some with bent ribs, some with raw sewn edges, some free standing ones which need a large bracket fixing to the vehicle. Yes have seen vehicle awnings retail for well over a £1,000 for just the awning. We have been offered single 270 degree awnings for 90 USD trade or about £55 FOB To date I have not seen a 270 degree awning of the same quality as the Foxwing, with the same range of accessories, with the same range of fitting kits and the same availability of spare parts. Will Foxwing withstand winds? Well correctly pitched with some extra guy ropes the Foxwing can withstand 55mph winds. That is not manufacturers figures but fro our experience at a rather windy Manby weekend and wind speeds from a weather station a few miles down the coast. Brendan |
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 ![]() ![]() |
well said Brendan i use mine in all weather yes you have to be careful putting up and down but once up and the right guy rope's out yo cannot go wrong
That was something else I was concerned about. Surely erecting a 270° wrap-around awning (regardless of make) can't be done by one person if it's anything like windy? The main reason I need cover is because I can't stand upright in my camper, so a covered area immediately behind the vehicle would become a kitchen once I fit a drop down cooker on the back door. Add to that the requirement of some type of awning along the vehicle's side, a wrap around seems the perfect solution ... but how easy are these units to erect/fold away? Would it require two people to stop it getting mangled during erection/dismantling?
yes you can as long as you uses and do it right RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Obviously I have to see all the different options in the flesh before deciding, but the Hannibal doesn't sound promising. We'll see, got to keep an open mind. Thanks for your input.
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
Has anyone used the armadillo awning? Saw it recently and looked better quality than most but also with a price tag.
I will be buying a awing soon (at least for next season) and will be buying on service, parts etc. I have narrowed it down to three of differing levels/prices and will be contacting all three and seeing who I want to deal with. One thing I have have noted is often quality = weight. |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
Another foxwing user here who has owned one for many years. In my opinion (and I haven't played with or used any of the others so is entirely based on...well...nothing), I cannot imagine them being beaten. It is the best bit of camping equipment I have.
In light winds you can put them up yourself but when it blows you will need two people. Word of warning though. I got a little giddy the first time I pitched it, which incidentally was very windy. I unzipped the case and let the wings flap down, expecting the retaining elastic strap to be strong enough to hold the poles in. It wasn't, and they were whipped out. One bent quite badly. It still pitches without issue, and also zips back into the case easily enough. It still works correctly and in 5 years of use I have not felt the need to replace the bent pole, even though spares are widely available. I have also never retreated the fabric and it is still as waterproof as the day I bought it. You do need to look after the newer poles though. I believe my foxwing was still made in Australia, but the newer stuff has been outsourced to china. I have recently bought an oztent and feel the poles are not of the same quality as the ones from my foxwing. Again, I have never maintained the poles from the foxwing and have had to replace 1 in all the time I have owned it. The same cannot be said for my more modern oztent poles, of which a few have seized solid, all within 1 season of use, even though I have lubricated them after each trip. Overall though, I am still extremely happy with the oztent brand, but am just trying to give you an unbiased view of their products. 2002 110 td5 |
![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] Ticks all the boxes I need :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Strewth Ken, do campsites charge you for three tents?
that was a good one Ken :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
