Home > Technical > Td5 engine thumping noise anybody experience of this????
Page 2 of 2 <12
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
Ok update
Removed flywheel and then tested for play in the crank. Play was still there Big Cry
Just for completeness I removed the sump and lay underneath while I moved the crank via the flywheel bolts and only bald of the crank was moving Shocked
So ian you were correct in your diagnosis Thumbs Up
The crankshaft has broken into 2 pieces.
So I guess that's me now shopping for a new engine Rolling Eyes
Anybody have a good one that they want to sell ????
Might start a new thread to help my search
Thanks to all who have offered advice Thumbs Up it is much appreciated Thumbs Up
Post #357636 13th Sep 2014 4:31pm
Porny
Site Sponsor
That's only the second Td5 that I know of that has snapped it's crank.
Wouldn't be the end of the world to fit a replacement crank... but really you'd want a full rebuild. I could do you a fully blue printed, balanced and ported race spec Td5. ...
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #357641 13th Sep 2014 4:44pm
amondeggs
Ian
You don't know how much I would like that but ....
Not sure I could afford it lol 👍
Post #357643 13th Sep 2014 5:03pm
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
Have never heard of a Td5 crank breaking before, would be really interesting to see pictures of where it's broken.
I guess it's a good advert for the Td5 engine that it hasn't got a reputation for breaking cranks.
At least we know what it is now.
It's normally the heads that let these engines down through cracking so assuming that your head is ok might be worth picking up a short engine and would probably work out the cheapest route for you
Dave
Post #357665 13th Sep 2014 8:02pm
amondeggs
As yet I have not removed the oil pump assembly from the bottom of the engine, but w will do and post some pics when I do Dave,
Cheers Thumbs Up
Post #357811 14th Sep 2014 4:54pm
Page 2 of 2 <12
