Home > In Car Electronics > CB SWR readings
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
CB SWR readings
Recently my CB has started to lose range (it may never have been that great).
The power meter display on the unit only gets to 2-3 bars on channel 1 and 4-5 bars on channel 40.
I've also put a SWR meter on it and despite moving the aerial up/down its height range in 5mm steps, the SWR reading stays around 6-7.
I've check the earth on the unit ( it goes back to the battery) and also cleaned and checked the aerial earthing and mount.
When the SWR meter is connected, the power meter display on the CB shows full signal, is this normal..?
Any ideas on what to look for/check to get the SWR down to a sensible level..?
Simon
Post #349526 4th Aug 2014 8:21pm
bob neville
When you say the earth is good is that from the radio and the aerial ?
If they are both OK I would then check the coax - it sounds a bit like a short somewhere.
Another trick I use is get an old metal coat hanger and straighten it out. Then cut to the length of the mast. Clean one end back to bare metal and replace the mast with the hanger.
Then check the swr on ch 1 and 40. Lowest swr on ch 1 means the mast is to long, lowest on ch 40 means the mast is to short. You can then take a bit off the temporary mast if you need to shorten it or reposition it if you need to increase length. I have found the adjustment needed is 1 or 2 mm, 5mm can make a lot of difference.
If you get good readings then you can shorten the real mast by the amount you took from the temporary mast or reposition the real mast to the extended length.
2013 Defender 90 CSW - sold
Post #349533 4th Aug 2014 8:54pm
couplands
Thanks Bob, I checked with a meter the resistance at the aerial to earth and also at the CB end. Didn't check the core of the cable, so may be that.
I was also thinking of using a bit of wire/coat hanger prior to cutting the aerial, but I'm so far off at the moment I need to fix that first.
Simon
Post #349536 4th Aug 2014 9:12pm
jst
there is no cont between core and shielding i take it?
what mount have you got?
have you tried thunderpoles forum and Q&As? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #349591 5th Aug 2014 7:29am
couplands
No shorts as far as I can see. Will recheck it all later...I still think there must be a bad earth somewhere. I'll get some new cable/connectors too, just to eliminate the possibility of a duff cable.
cheers
simon
Post #349593 5th Aug 2014 7:33am
shaggydog
Worth a look at the cable.
Last one I bought came from ThunderPole and the soldered connections were terrible and had to be re done, not that it mattered because the cable was broken somewhere in the middle.
They did however apologize and send me a new one.
Post #349645 5th Aug 2014 12:21pm
couplands
This might be a stupid question....when talking about an earth for the CB unit, is this in addition to the positive/negative connections..? I have taken both of these back to the battery directly (via a fuse in the +ve cable), but just wondering if I need to separately ground the CB case..?
Just looking for reasons why the signal is rubbish..!
Simon
Post #349919 6th Aug 2014 12:15pm
jst
you shouldnt need to earth case sep.
did you check Tp forum?
there is cont between the shielding, case and body i take it but not with the core? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #349928 6th Aug 2014 1:05pm
couplands
Yes, checked no shorts between core and shield.
Looking at the TP forum, it seems my issue might be related to the fact that the spring on my aerial is below the roof line (I have it mounted off a bracket fixed to the rear door hinge). Seems the spring needs to be in clear air.
Here's the bracket:-
Will try lifting it up, although the reason I dropped it below the roof line was to offer some protection from trees etc.
cheers
simon
Post #349932 6th Aug 2014 1:54pm
couplands
It was definitely the position of the aerial close to the body that is giving loads of reflections and sky high SWR readings.
I've jury rigged it higher up and can get the SWR to around 2.5 on channel 40.
So, where do I fix it permanently....I was thinking on the roll cage, centre above the windscreen. Any better ideas..?
Simon
Post #349951 6th Aug 2014 3:20pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I have one of these on the back
http://www.thunderpole.co.uk/fixed-body-mo...t-kit.html
You can also get gutter mounts 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #349959 6th Aug 2014 4:03pm
CFB
Only way I have ever got a perfect SWR is using a body mount straight through the roof! OK on an old off-roader but wouldn't be so keen on a newer one. Andy
Post #349995 6th Aug 2014 7:21pm
couplands
^^^ Ive ordered some exhaust clamps so I can bolt the aerial mount to the front roll-cage bar. I'm going to get this CB rig set-up as perfect as I can, plenty of clear space around the aerial and super grounding through the roll-cage.
Wish me luck..Wink
cheers
simon
Post #349997 6th Aug 2014 7:24pm
jst
i have one with the body mount - works well even though part of it is below roof line around 1.8SWR. and another with a through mounting on a roll cage (plate welded on) that give 1.5SWR and works really well. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #350043 6th Aug 2014 9:39pm
couplands
Today I made the new mount for the aerial. Not had chance to wire it up, but hopeful it will get a better SWR reading than before....
Simon
Post #350659 9th Aug 2014 7:51pm
