![]() | Home > Tdi > Clutch Rattle |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
Most likely is a broken spring I would have thought. My last clutch had that, and I ignored it. When I swapped the engine over I changed the clutch as a matter of course, and it had a broken spring.
Only an issue if it falls out, although mine was never going to! could also be a worn release bearing I guess, but sounds more like the spring. I wouldn't worry about it, unless you're getting the gearbox & engine apart for any other reason. |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
mine does does it, but its very intermittent! so might go 3 weeks and then here it dip clutch a couple of times and its gone for another few weeks!! My 109 thread
my youtube channel |
should have said, clutch was done 30K ago My 109 thread
Diabalo - Good point may be a broken spring, however as you say I don't think it will fall out and if it does will just get stuck to the grungy oily clutch dust and oil mess which is probably all over the inside so i cant see it being a problem.
G-mak - Exactly like mine! Didn't do it at all today, but previous 4 had done! I think I will wait until it starts giving up or the engine leak gets worse. I have definitely made my mind up to do Rear main oil seal and clutch and gearbox oil seals all at same time so its only dropped once. |
Mine's the same, but I'm very much of the opinion that if I ignore it it might go away
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Yes I have a similar attitude. Traction engine methodology 101: "if you hear an unfamiliar noise, listen to it for a hour, the noise is now familiar so it must be fine!" |
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 ![]() ![]() ![]() |
Id say clutch release bearing. My tdi does it and has done for years... Wouldn't be particularly worried about it to be honest.
