![]() | Home > Td5 > HOT! R380 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
I'd be interested to see how hot my r380 gets when cruising at 85!
I have wondered about cooling myself, I think irb do a kit, I wouldn't have a clue about diy cooling ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Stue5 Member Since: 06 Jul 2014 Location: Marche Posts: 111 ![]() ![]() ![]() |
I am preping the defender for going back to Italy so just a little concerned with the temp as i was only doing 70mph, when on the continent will be wanting to cruise at 75-80mph @+30c
![]() Have found these pipes..... don't know whether they would work on the td5 as they are wolf= ESR2749 the block FTC2104 is a "thermostatic" which opens when at the correct temperature, because i don't want to cool the box when driving in the mountains in winter(-16c) Range Rover p38 4.6 99 lpg(gone ![]() ![]() |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
I have a full wolf setup ready to fit to my Td5 at some point.
You'll find that the pipes need a bit of bending to fit around the engine (although not a huge amount) but fitting the cooler in it's factory position will be awkward, especially if you've got a larger intercooler. I may end up fitting mine up inside the wing somewhere. I may also end up chopping off the steel rigid pipework and getting some Goodrich type braided hose in place; will make it far easier to route. |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2956 ![]() ![]() |
How. Do you fill the gearbox with an oil cooler fitted
There's a thread over on LR4x4 about the very same subject.... (filling with a cooler)
General consensus, and the workshop manual too, states just fill it to the normal level. there's not that much oil in the pipes and cooler, half a pint maybe? |
I think that the cooler doesn't empty while changing oil so only after installing you need to run it till warm and then check the level again. You probably need to add a bit at that moment. Roel
