![]() | Home > Td5 > Alarm? |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 ![]() ![]() ![]() |
Hey folks,
When I bought my defender, it didn't come with it's log book or it's service book. The chap I bought it from is trying to find it in his house! I have read that there is a security code on the security section of the hand book that should outline the alarm code. What's the story, when do I need the code? I was wanting to establish what I do or don't do before and after disconnecting the battery. 2001, 110, CSW. Thanks in advance folks. Cheers Andy |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
The security code is a manual way of overriding the alarm in the event of a key fob failure. It involves turning the ignition on and off to enter a four digit code and opening and closing the drivers door. Should only need it if you lose the fob. Should be fine to remove the battery
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 ![]() ![]() ![]() |
I bought mine from an independent dealer in Hampshire in March. They didn't get the service book etc from the previous owner so I didn't get the code either. I went to see them a couple of weeks ago and mentioned this. They phone Land Rover and got the code straight away with no problems. A local independent or main dealer might be able to help, but I guess you'd need to prove ownership first.
Awesome lads, thank you ever so much!!
Battery disconnected, reconnected then disconnected again ![]() All good, am removing the dash to get access to some areas of rust! Cheers Andy |
Hi pete,
Thanks for your mail though, it's much appreciated being able to ask knowledgable people for advice.. Today I took the landy to paint shop for estimate to touch up and pain the bodywork (once I replace the doors and bonnet), they really didn't give the impression the wanted to do the work. Just seemed to point out problem after problem (where do you stop). I know when people don't want to do something and I felt that's what I was being told today. A shame as I do want to sort some of the problems and smarten up the paintwork....... I guess I could try further afield than Aberdeen (where it's normally 25% more expensive then everywhere else ![]() Cheers Andy |
