Home > Maintenance & Modifications > Tyre sizes
peterl
1987 Defender 90 300 Tdi HT Epsom Green
Tyre sizes
Just a quick question to those who know, do 235 x 85 x 16 and 265 x 75 x 16's have the same rolling circumference? Can I run them together and not damage the transfer box?
Post #29498 11th Apr 2010 11:53am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
They are almost the same diameter according to my calculation ie 238 x 85% and 265 x 75%. There are differences however between manufactures too.
Personally I think you will be save but I am not an expert.
If your front tyres or rear tyres are worn more then the others you don't directely have problems so that why I think you will be save. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #29500 11th Apr 2010 12:04pm
Laurie
Is it legal to run different sizes on the same vehicle?
I've never thought about it.
Post #29502 11th Apr 2010 12:17pm
peterl
The only reason I ask is that they were on there when I bought the 90, just wondering if I can get a few more miles out of them.
Post #29503 11th Apr 2010 12:35pm
bob neville
Put your tyre sizes into this calculator and you will see the answer Thumbs Up
I don't know if you can run the different sizes together but I am sure somebody will have an answer.
http://www.miata.net/garage/tirecalc.html
Bob
Post #29507 11th Apr 2010 2:52pm
CFB
I think as long as the axle pairs match it will be fine Andy
Post #29519 11th Apr 2010 5:33pm
MK
different sizes will make the center diff work harder Puma 110" SW
Post #29522 11th Apr 2010 5:39pm
CFB
235/85 circumference is 99.7"
265/75 circumference is 99.4"
As they are so close there will be no issue running these as long as a pair of each is on each axle as previously stated. Running worn tyres and new would have the same if not greater effect. Andy
Post #29527 11th Apr 2010 6:40pm
alantd
So long as you have the same sizes on each axle you're fine.
A lot of cars run larger widths at the back.
Obviously you'd never want to run different widths on the same axle because they'll have different braking performance.
Those are nearly identical in circumference - use Bob's link. There was a thread on this recently and it was concluded that the extra work in the centre diff would be negligible. One that started out as a 2.4 TDCi 110 XS
Post #29555 12th Apr 2010 4:13am
