Home > Tdi > How much?
jason110
How much?
Hello!
I'm after a 110 station wagon TDi, either a 200 or 300. I've got a budget of around 4-5k and I'm wondering what kind of wagon will that get me. I'm not after perfection! I would like something serviceable, that isn't on it's last legs or riddled with tin worm. I am not to bothered about cosmetic condition.
What does everyone think? Am I deluded or are there some resonably priced wagons out there?
Cheers jason
Post #344492 11th Jul 2014 11:32am
shaggydog
For 5k You can find a very very nice 200Tdi 110.
For £4000 you will probably find a good one, which needs a few things fixing.
I got mine for about £4000 and have had to replace the rear cross member and am now getting the bulkhead replaced.
One comment I will make however, if you have to choose between rusty bulkhead or rusty chassis, go for rusty chassis because it is a hell of a lot cheaper to replace a chassis then a bulkhead.
Take your time, there are loads of them out there it is a matter of waiting for a good one and going to see it. if you turn up and they are a bit dubious about you giving the chassis a good tap with a hammer or going for a test drive then treat it suspiciously.
Good luck with the hunt!
Post #344511 11th Jul 2014 12:34pm
g-mack
have a look at my thread and see what i got for 5.5k Thumbs Up
link at bottom of post Thumbs Up My 109 thread
my youtube channel
Post #344523 11th Jul 2014 1:42pm
jst
Shocked Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #344535 11th Jul 2014 2:32pm
jason110
Thanks guys. It will be a while yet, I'm away with work at the moment. I've been looking for a while, but the mix of trucks and prices seems to vary quite widely.
I have seen your truck g-Mack. I'm pretty envious to be honest!
If anybody sees something tidy, let me know!
Cheers jason
Post #344689 12th Jul 2014 11:18am
jason110
Do 200tdi defenders have disk brakes all round? Ta
Post #344718 12th Jul 2014 4:27pm
gilarion
Yes they do disk brakes all round
Post #344726 12th Jul 2014 5:24pm
Lou Sparts
I thought disc brake rear axle came with the intro of the 300 Tdi. Could well be wrong though. 2005 Td5 90 XS
Steve
Post #344728 12th Jul 2014 5:30pm
g-mack
no they don't!! they have drums on rear! well 110 did anyway My 109 thread
my youtube channel
Post #344753 12th Jul 2014 7:01pm
jason110
Cheers gents! I think I may favour a 300tdi in that case.
My last 110 was a 1986 vintage and I rather despised the drums on the back of that! I know I could most likely Censored about changing the rear axle, however I would prefer not too since my workshop is 60 miles from my bed!
Jason
Post #344790 12th Jul 2014 9:30pm
mikeh501
Fitting a disco1 rear axle is a simple mod to get disc brakes on a 200tdi 90. Mine has disco axles front and rear.
Post #344815 13th Jul 2014 6:15am
udderlyoffroad
A disco axle is NOT rated for the weight of a 110. Fine on a 90 though.
Yes, the disc brakes were introduced with the 300 Tdi, however because Land Rover tended to use what they had lying around in stores, and because it's easy enough to convert them with OEM parts (I've done it on my 2.5 NA petrol), it doesn't mean you won't find a 200 Tdi 110 with disc brakes. Just make sure it's not a disco conversion - google images for 'Salisbury axle' - this is what should be fitted.
In fact, I'd look for a truck with a good chassis and bulkhead, and if it's not on discs on the rear, budget £300-odd to do the conversion, or £500-odd to have it done...
Good luck with your search!
Matt Real trucks don't have spark plugs
Post #344847 13th Jul 2014 9:53am
shaggydog
/\/\/\ +1 Thumbs Up
Post #344848 13th Jul 2014 10:12am
jason110
Thanks for that. Top bit of info there.
When something pops up, I'm sure I'll be along with more questions.
All I'm after is a tidy wagon I can use locally to bimble around in, with a bit of green laning thrown in.
Jason
Post #344853 13th Jul 2014 10:35am
familymad
Sell it sell it (to me). Laughing 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #344885 13th Jul 2014 2:34pm
