Home > Maintenance & Modifications > Drip from rear diff
Page 2 of 2 <12
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
Terrmafirma do a kit. Found this one via a search engine search;
http://shop.challenger4x4.com/terrafirma-t...1462-p.asp
I don't have one so cannot recommend either way.
Hope this helps
Post #345250 14th Jul 2014 9:49pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Thanks,
Appreciate it, also found a couple of other kits on ebay.
I don't think there would be any issue combining the axle and fuel tank breathers into one manifold eh?
Andy
Post #345255 14th Jul 2014 10:04pm
timtom1
United Kingdom 2001 Defender 90 Td5 CSW Alveston Red
Rugged Guide have a video on how to fit them breather pipes
 2001 90 TD5 CSW Alveston Red Manual
Post #345285 15th Jul 2014 6:45am
I think it can be done with any normal push to fit air hose and unions - I think aquariums have been quoted in the past as good cheap sources of the appropriate kit.
Also, worth considering one of these:
http://www.ebay.co.uk/itm/4-into-1-Wading-...3ce43367cc
if you don't want multiple tubes running up the snorkel.
Post #345292 15th Jul 2014 7:28am
jst
unless you are going to put in one way valves i wouldnt run them together, what if oil does come up one of them and finds its way back down another? - yes it happened to me!!!
i use 6mm pushfits and lenth of pipe to suit. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #345467 15th Jul 2014 8:41pm
Page 2 of 2 <12
