Home > Puma (Tdci) > horn plus 'flasher'
horn plus 'flasher'
can you guys think of any reason why i can't use either horn or lights flasher (pull toward you) ? Could the fuse be gone? IF so where may it be? I can use dipped and main beam lights fine (main beam pushed away from driver) I have spots all 100% wired and fused correctly however i do have this problem. they worked when i first had it 2 months ago but since failed. 90 puma 57 plate
Post #29165 6th Apr 2010 7:06pm
alantd
Sounds like a faulty switch in the steering column to me. Suspicious that there's clearly nothing wrong with the lights wiring - just the stalk. One that started out as a 2.4 TDCi 110 XS
Post #29171 6th Apr 2010 8:52pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
The flashers and the horn run from the same fuse so that's worth a look. The fuse you want is in the secondary fuse box under your seat, and is labelled F3 here:
 Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #29172 6th Apr 2010 8:52pm
wyvern
it's probaboly the stalk - had the same thing happen to me on our TDI, TD5, and on the Puma.. .. Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #29182 7th Apr 2010 5:29am
right i'll have a check of the fuse first off then maybe move onto the stalk. Would this fail an MOT? also i think that a new indicator stalk is plug and play? other than removing and refitting
Post #29202 7th Apr 2010 11:56am
Glynparry25
If you can't beep yor horn it will be a fail. As you have put....best check the fuse and then the stalk, and it will be a simple plug off and on Very Happy
Glyn Sheep
Post #29204 7th Apr 2010 11:59am
checked fusebox today seeing as i thought about it Shocked thank-you for the fuse box diagram that really helped Thumbs Up yes the correct F3 fuse is blow i should imagine it's because the spot lights i have were wired up wrong when i got it and thats done it as i replaced them. problem is i don't have a 20A fuse just now Sad
Post #29335 9th Apr 2010 11:09am
replaced fuse with same rating replacement. and all is well every thing is working now Smile thank you to all that helped Thumbs Up
Post #29351 9th Apr 2010 3:08pm
