![]() | Home > Td5 > Fuel Pump relay constant clicking ( buzzing) on startup |
GreigP Member Since: 13 Apr 2014 Location: aberdeenshire Posts: 18 ![]() ![]() ![]() |
Hi Guys,
been playing about today and I have run a test earth from one of the ECU mounting bolts to my battery and this seems to fix it... as when I remove it the problem is back again.. So I guess I know how to fix it but I am not sure I understand what has gone wrong... ie all of a sudden I have an earthing issue, or it's maybe something I stuffed up with my twin battery config.. ![]() Anyway It looks as if that's the fix for me ( in case anyone else comes across this) happy for any thoughts ![]() cheers, Greig. |
The vagaries of the Td5 are more fickle than any woman in your worst nightmare. Mine often throws a wobbler and has me completely stumped, then it will just disappear into a distant bad dream. It may have been the result of a bit of pulling or tugging somewhere when you were adding bits.
Where have you taken the negative feed for your Blue Sea? Ideally it should be off the battery. I gather the problem wasn't there before the dual/Blue Sea installation. As the issue is a known earth one it shouldn't be too difficult to nail down.
You have a high resistance earth somewhere and by 'jury rigging' a new one you are providing an easier less resistive path. Disconnect the batteries and check/clean your major earths starting with the one off your battery. Good luck. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
hey cheers for the replies.....
![]() yeah the -ve feed for the bluesea comes direct from the secondary battery via the pre-wired 1mm cable (and a corresponding 1mm brown to the +ve) (i say 1mm but it could be 2....anyway... very thin and protected by 2amp fuse. yeah the problem "wasn't " there before.... ![]() ![]() thanks again guys G |
is it a earth problem because of the twin battery set up , did you change any earth cornections ?
The twin battery setup is pretty much as per the LRO configuration document ( also in in the haynes tuning book) so I have not changed the original earth.. from the starter battery to the chassis etc... I have only run a connection from the starter -ve to the secondary -ve
The live feeds are connected via the bluesea ACR...which kicks in after 30 secs of charge and joins the batteries......and disconnects when not being charged. My secondary battery feeds into a bluesea fusebox and earths back to it. ( this will feed power further shiny gadets on the raptor dash) I did check all the earths for continuity with my multimeter... and they seemed ok ( but not sure if this proves much) but as K9F says, its defo an earthing fault and it wasn't there before, so its probably worth checking what I've done. The batteries are shiny new odessey pc1500's so not sure "they'd " need much cleaning , and most of the cables / connectors a new too......but I'll check existing connections just in case moving / bending has upset something.. if / when I get a result I'll post up for completeness... ![]() cheers, Greig. |
deleted
I should have added...when I ran an earth from the ECU to any good earth point ...ie bulkhead or my battery holder it also worked......so not "just" back to the main battery -ve...
This made me think the earths on the batteries were good and that it was the ECU earth side that was playing up... anyway..I'll check tomorrow ![]() |
